CR123 Voltages
jack-n-barra
Queensland Australia
No Takers on this one?
I will explain a little more I have just purchased a 2 X CR123a LED torch and now it will not stay on when I depress the switch and was wondering if the battries could be flat already? The only way I have to test them is a digital multi meter and they both measure 2.79V.
Is this flat or below a limit that will hold the switch on?
Cheers
Tod
45/70
Rural Ohio
Hi Jack, (err, Tod:)) . Unfortunately, there isn't really any way to estimate primary lithium cell capacity by measuring voltage alone. Unlike Li-Ion cells, the voltage means little, and a cell with a lower voltage could actually have more capacity left in it than one with a higher voltage.
The only way to get any kind of accurate estimate, is to measure the voltage when the cell is under load, such as with a ZTS tester, or similar device.
Dave
jack-n-barra
Thanks Dave, Have got some AW 18650-26 Lion's on the way will wait and see if this makes a difference.
Don't want to go and buy any more CR123a's they are way to expensive here in AUS I hav to pay $20.00 a pair for something that only lasts an hour or so.
Cheers
Tod
mdocod
COLORado spRINGs
Hi Tod,
While there is very little correlation between voltage and remaining capacity on primary CR123s, I'd say that voltages below 2.9V can have some meaning. That meaning is usually dead.
Just as an FYI: You can buy primary CR123s online for under $2 each. (I still think you'll prefer the 18650 cell though).
Eric
45/70
Rural Ohio
Hi Tod,
Yeah, I probably should have said that, but I was mainly trying to get across that you can't really tell a whole lot about primary lithium cells by just measuring voltage. 2.79 Volts is for sure in the "dead zone" though for all but possibly single 5mm lights and such.
Dave
