3_gun
- Joined
- Jun 27, 2021
- Messages
- 645
So I got bored today & did a RT test on my Sofirn IF25a/4K light. That bring me to this .. most run times are BS marketing propped up by an ANSI standard that most don't understand. It is ..
"The duration of time from the initial light output value (that's 30 seconds after the light is turned on with fresh batteries) until the light output drops to 10% of the initial value".
Not really useful in the real world if you buy a light needing 2000L for 2hrs but end up getting 2000L for 1min and end up at 200L at the 2hr mark. That's what a F1 test allows to be reported as run time
So I picked a level that I use often for normal GP flashlight use .. 125L. I used a fully, freshly charged quality battery & just let it run until the FIRST step down, making notes of the starting & ending volts.
Light .. Sofirn IF25a @ 4000K
Battery .. Samsung 30T 3000mah 21700
Level .. 125L
Time .. 8 1/2hrs
Starting V .. 4.2 Ending V .. 3.0
Try and test a light level that is a normal set level for that light. Sofirn reports the IF25a starts at 125L after a battery change so I set that as memory for testing. I don't know that it really is 125L but every IF25a should be close to that doing the same thing. I tested using stepped ramping so the step down would be clear; some lights might be harder to tell but do your best
So lets get some REAL numbers to compare. Use whatever light you want just be sure to stick as close as you can to the outline.
Light .. Fenix E35 v3
Batteries .. Fenix arb-l21 5000mah 21700
Level .. 450L
Time .. 5 1/4hrs
Start V .. 4.2 End 3.1
Who's next?
Level .. 125L
Time .. 8 1/2hrs
Level .. 450L
Time .. 5 1/4hrs
Who's next?
