Well, after 30 days self discharge on the cells, the effects of 15 minute charging are becoming clear.
Under a 1 amp load, the voltage of the cell dropped almost to 0.9 volts, then held for awhile. Gradually the voltage climbed to over 1.0 volt, but that was about as good as I could get.
Normally, Eneloop cells will test at around 80% on my ZTS tester after they have been sitting for a few weeks. These cells tested at 40%.
It looks like they lost around 15% of their capacity in 30 days after all these cycles. I could probably bring them back for daily use, but if they were sitting on the shelf for any length of time, the internal resistance will go up to the point where they would be unable to hold voltage under load.
Very interesting test.
I try and get the graphs up in the first post shortly.
Tom
