Can someone please explain why there is no balancing required? My knowledge in these things is lacking-
I thought that when charging cells in parallel, some sort of circuitry had to be in place to make sure each cell was charged equally.
Balancing may be required.
You as an end user need to be aware of what state of charge exists in your cell (by periodically monitoring voltage etc). Conceivably if you have start off using two cells at the same state of charge (hopefully both full) at the end of use both cells should be similarly discharged (monitor voltage anyway for your own safety).
Consider the charging jack a convenience feature, all the safety rules still apply.
Thats the same build I plan on doing. What do you think about it?
