E1E & E2E Incan Question.
soldonsurefire
Is it possible to safely drive an E1E incan bulb with a single 16650 li-ion 3.7 volt battery?
What about an E2E incan bulb driven by the same single 16650 li-ion battery?
chillinn
Mobjack Bay
MN01 is 20Lm at 3V and draws 1.06A (<-- my educated guess at current based on runtime and capacity of CR123A, but may have as little as 0.9A draw). CR123A voltage, however, will sag to about 2.55V under a load of 1A, so it's really only a 3V lamp nominally. Because of that, it drives nicely on two NiMH 1.2V, but two fresh alkaline may flash it, and two Energizer Lithium definitely will. MN01 will immediately flash on one 3.7V liion or 3.2V LiFePO4.
MN03 is 60Lm at 6V and draws 1.08A, but, again, CR123A voltage sag means it's really about a 5V lamp, which means it will safely drive quite nicely, though be slightly under-driven, on one liion for maybe 50Lm.
MN03 is 25Lm at 6V and draws 0.51A, though CR123A voltage sag means it's a little over a 5V lamp, 5.2V, 5.4V, somewhere in there. It will also safely under-drive nicely on one liion for about 18Lm, and on one 3.2V LiFePO4 for maybe about half that brightness or a little more, and amazingly, MN02 will also fire on two NiMH 1.2V for about a lumen, and with 2000mAh cells has a very long runtime of about 4–5 hours. As yet, I have been unable to flash an MN02, but two liion should destroy it.
I remember the threads here about under-driving lamps in 2014—2016, and the explanation is that giving a lamp less voltage will foul or slow the halogen cycle, leaving more soot on the glass, and darkening over time, and shortening the life the lamp.
But I have been under-driving lamps quite a lot, especially MN02 and Tad Customs lamps, but also MN03, and I have not seen this occur, lamp darkening, not in 8 years of doing quite a lot of under-driving, and I have seen no evidence of it whatsoever in any of Surefire's E lamps. In my experience, under-driving lamps merely gives less lumens and lower color temperature, but also extends the life of the lamp, not shortens it, with no perceivable darkening. Current draw is unaffected, i.e, it doesn't change with lower voltage, practically speaking. Safely overdriven lamps should draw more current as per LuxLuthor's Destructive Incan Bulb Tests, but I haven't been able to detect any reduction in current under-driving E lamps at these relatively low voltages and current.
The only lamps I have seen get dark are some Lamptronix bipin avionics lamps (Maglite Mini and Solitaire sized lamps) I found on eBay years ago, and they got dark when fully driven and overdriven.
Mark at Lumens Factory (closed until 24 April for site upgrade) still sells E Series lamps designed for liion voltages, apparently now built to order (he told me he does not keep inventory of incan lamps anymore, makes them as the orders come in).
Tad at Tad Customs once sold a handful of lamps for liion voltages (1.2A 3.7V, 1.8A 3.7V, 1.0A 6V and 1.2A 7.4V, among others), but he closed his web shop a couple years ago. With Tad's assistance and blessing, I am working on sourcing those lamps from the manufacturer, but they'll require a socket to be used, as they are bipin lamps. (And if/when successful I'll contact Mister Ed to figure out a way to make them available to other CPF members that want them).
According to fivemega, Streamlight bipin lamps also can be used in E with liion, but they'll also require a socket, but I don't have voltage or current specs on them. fivemega also used to sell a socket for E, as well as a G2 halogen bipin lamp custom made for him by Carley, the 1794, that is 6V (7.4V) and 3A for 1000Lm of lovely halogen. I sure wish we could get more of those. They require a socket and were too long to fit in an Elite head without modification (unscrewing the bezel a little and adding a small ring to move the lens further away), but the modification is non-destructive and fully reversible.
chillinn
Mobjack Bay
But there's so much more.
There's E to C adapters, so that P60 heads can be used on E bodies, allowing the use of P60 dropins. Lumens Factory sells a P60 to E Bezel Unit for Surefire E Series and so does Malkoff (both of which are like a P/C head with the E body adapter built-in).
Surefire P60 dropins are still plentiful on eBay, and Lumens Factory sells dropins for 3.7V, 6V, and 9V (7.4V), and
Kaidomain sells 3.7V 15W (4.05A!!) dropins especially for single cell liion as well as dropins for 6V, 7.4V, 9V, 12V & 14V, and Solarforce dropins in the same voltages.
soldonsurefire
I became aware of Lumens factory while searching ebay for some deals on Surefires.I searched online and found their website.I emailed Mark and ordered many of their products.
Here are two.A teardrop head and their own design of a head that holds a traditional P60 drop-in.
I placed a head from a 6P, in between the E2E's, just for scale.
ampdude
USA
I actually hadn't seen that one on the right before. I really like that M3'ish design and the fact it holds a D26/P60 drop in.
soldonsurefire
That's the one.Although they don't display it disassembled.
It's a combination of an E to C adapter and a head to hold a P60 drop in.
Buck91
USA
Well now, that would be quite interesting indeed.
ampdude
USA
Fm, isn't he referring to the regular 3 volt bulbs? Those 3.7v batteries will kill it. Unless I'm mistaken and read this thread wrong.
vicv
Southern Ontario
Using those keep power cells is still going to overdrive the bulb though. 1 may be fine. But I bet, in a 2 cell light, will definitely flash the bulb.
For that kaidomain 3.7v 15w drop in, I've bought those and the 10w ones. They both draw around 2A. They're the same drop in and really 8w. They're very good though. About the same as a lumens factory ho-4. But a little bit throwier. Haven't burned one out yet either. My oldest is about 8 years old and I run it a lot on imr 18650 cells. Still bright and white.
fivemega
California
They are not 3.7V batteries. They ere regulated to nominally 3 volts and drop to about 2.5 volts under load just like primary CR123A
No, won't overdrive. As long as battery length fit, will run on 1 cell, 2 cell, 3 cell, and 4 cell lights just like primary CR123A
Make sure read all specification of that
KeepPower batteries.
vicv
Southern Ontario
OK. Did not realize they dropped that much underload. Quite surprised. I would assume that if a battery was designed to be regulated at 3 V, it should output 3 V. Regardless of the load. Within reason.
