E2 head fitment to M500
RockGlock86
NEPA
Will the E2XTD head fit on the surefire m500 foreend and has anyone done this before? any experience with run time or throw and any experience with use on a 14.5 M4? Thanks for your time.
chillinn
Mobjack Bay
I believe it would take a M to E adapter. I'm not sure those exist. Never mind, I had the wrong model in mind.
I have a E to M adapter. E on the brain here.
E2XTD is not for fits E Series, M600, M300 and M1.
But I think it would work without an adapter because both M500 and M600 have M head threading, no? No. I made an assumption that may be incorrect. The head on M500 looks like a z46 to me, but maybe it isn't.
No, I'm right. Surefire M3, M500, M900, M910, M961 & M962 all have the same M head threading. idky M600 is not in that list, because it should be. because it's an E! The E2XTD will screw onto the M500, so you just have to match voltage, which shouldn't be too difficult.
Nope! I am completely wrong. I was right the first time. If such a thing existed, you would need a M to E adapter, and I've never heard of one. It would be a weird adapter because that head would fall right through the middle of M threads.
Welcome to CPF, btw.
RockGlock86
NEPA
Boy trying to boil all that down made my brain a little hot...
So the E2 head is not swappable or adaptable, I appreciate your detailed response. I have been looking here trying to see if there was a listing of what parts work with what and I haven't found one yet.
Is the Malkoff MDM4 with a M91 drop in more what I am looking for?
Or the Malkoff MD90 adapter?
My goal s to be able to retain the M500 system which I already have and am very familiar with working with and get more lumens and more candela. Optimally I would like to be over 20k candela if not closer to 50K+ and somewhere in the 600-1000 lumens range.
chillinn
Mobjack Bay
Yes, MDM4 w/ M91 drop in for 3x CR123A or 2x Li-ion 16340
No, Malkoff MDM4 M91 Adapter
Malkoff said:
The Malkoff MDM4 Adapter will fit most Surefire Millennium Series Lights including the M3, M6, M500, M961, M962, M900, and M910.
Sorry about before. ><
No, not in that direction. All E are compatible with each other. All M are compatible with each other. There is an adapter to use M heads on E bodies, but not the other way around.
This is not remotely comprehensive, but should give some idea of M and E differences.
Surefire M
z46 older finned style
z46 bottom (incan)
z46 newer
KL2 LED conversion head
I forget what this is, but LED
KT1 or KT2 turbo head incan
KT4 w/ flat bezel incan
KT4 w/ crenellated bezel incan
LED turbo head conversion
I did not know this LED conversion head existed
___________________________________________________
Surefire E
Surefire E2 Executive
Surefire E2 Executive head/bezel "teardrop" (Some have no etching, E1 is identical)
Surefire E2e Executive Elite (older 3 flats body)
Elite head (older with smooth bezel)
Surefire E2E Executive Elite
Elite head/bezel with crenellations and MN03 lamp assembly
Surefire Executive Defender older
Surefire Executive Defender LED
E2E w/ older style KL1 LED head
Surefire E2o Outdoorsman older
Surefire E2L Outdoorsman LED
E2e's with newer style Kxx LED heads
EDCL-2T
Tactician
