Marquis07
I recently got a replacement TC15 with a cool white XHP35.2 in it, so I tried to swap out the emitter. I had done 2 sst20 swaps before, so I was feeling pretty confident. First off, I attemped to swap the emitter to this 5000K XHP35.2 I tried to heat the mcpcb with my solder gun on the bottom, but it was not working, so I used a torch instead. I did get the new emitter on, but I think I had too much or too little solder under it, and it was not aligned correctly. When I tried to reheat and align it, I bumped the emitter, and the dome fell off. All was not lost though. I also bought this 4000K XHP35.2 at the same time and I had an extra mcpcb from a broken light. I used a sheet of tinfoil covering a pan to heat up this second mcpcb and the emitter. All was going well, when suddenly black goo began coming out of the mcpcb, and the top started coming off. I rescued the second emitter, but it was too late. The base was seperating off of the top. In the aftermath, I realized that although I used a temperature gun to see how hot the tinfoil was, the pan was actually much hotter underneath. Instead of gently heating the mcpcb around 200F, I cooked it around 500-600F!
I now have a scorched but functional mcpcb and the original XHP35.2.
I still want to put a better emitter in the light, but for now, I want to get the original one back in. What should I do differently to have a better chance of success?
Before I order the emitters again, are these both fine for the light? 5000K XHP35.2 4000K XHP35.2 The second emitter is actually flat. How would this affect the light, and is it a bad choice because of this? The reflector is medium OP, although I have a smooth one I could use instead.
Following this thought^, Is there a better emitter that I should use instead of those? I would like it 4000-4500K and preferably hi cri.
I am also getting replacement 16mm mcpcbs. Would these XP16 v2 work, or would I need these XM16 v2?
I don't have solder paste, but I am planning to get some when I get my replacement emitter. Is it worth getting, or should I stick to just regular solder and flux?
When I swap the next emitters, I'm going to use a pan and solder paste. If there's something better I should use, please let me know.
Thanks,
Mark
Thanks,
Mark
