failing led floodlight killing grass
Olumin
"...that famous Texas part of Hamburg"
Most LEDs do not output any UV light. Here is a colour spectrum of a LED floodlight, clearly showing no output much below 400nm & certainly none of the harmful UV-B or C. Admittedly this light isnt HCRI, but in regards to the UV question it demonstrates the point. The graph provided above shows the same thing, the valleys on either side represent the baseline or "zero".
chillinn
Mobjack Bay
Those sources are exaggerating. All LED begin as blue LED and therefore emit a small amount of UV. If the phosphor is compromised, the amount can increase. The fact that turbodog specified purple guarantees there is UV being emitted, and we know it isn't actually purple because purple is a color mixture. Violet is the spectral color. And unless turbodog's floodlight is a freakin' violet laser, it is beyond all doubt emitting some UV.
Look, I realize I'm not popular, but it's crazy that I'm so unpopular that if I believe the truth, some will insist on believing utter crap. LED emit a small amount of UV, shown by a Google image search for "LED color spectrum" where every single germane image shows UV emission, and everyone is just going to have to deal with that. Because in ten million years I would never care whether anyone agreed with me or not. The crowd is untruth.
idk if you're blind or what, but the spectral graph used there clearly shows shows emission down to at least 325nm, well below visible light in UV-A, and that lamp may even have more. The poster is focusing on the amount of blue and green, which in comparison, the output of UV is negligible, but it is not nothing. And the lamp's spectral output will change over time. How is anyone's guess, but turbodog's anecdote strongly suggests that with the spectral shift, the amount of UV emitted can increase.
Olumin
The thing is that the tiny amounts of UVA (below 400nm) LEDs emit are insignificant, especially compared to other light sources and of cause the sun itself, which all emit significantly more UV. To me it is exceedingly unlikely that a average white LED, even without the phosphor coating (delamination), could give off enough UV light to kill or damage grass.
Is it impossible? Can I say it with absolute conviction? No. The excitation spectrum of LEDs is anywhere from 365 to 450nm. Even so, the vast majority will not emit much of anything below 400nm. Some might, but it is far more rare. It is impossible to tell without knowing the specific brand & model of LEDs used in the floodlight discussed above and without performing a spectral analysis. Rather then entertaining the unlikely or extraordinary, I prefer to first consider more ordinary explanations.
Edit: source.
jtr1962
Flushing, NY
A rather pedestrian explanation is that people simply walked more on grass that was better lit, killing it off. Certainly in public places this happens.
chillinn
Mobjack Bay
Then the goal posts have moved. It's not that LED emit no UV whatsoever, it's that UV output is insignificant. I can agree with a new LED, but not necessarily with an LED with 5000 hours on it. When we make grand sweeping arguments like these, they are bound to be wrong because it only takes one counter example to show they're wrong. Unless you're ready to argue his floodlight is a violet laser, turbodog's anecdote is that counter example, because if he thinks it looks purple, it is very probably violet, and if it is indeed outputting violet, then it is also outputting UV because they butt up against each other on the spectrum. Why is this so difficult to accept? What does it matter whether it does or doesn't?
jtr1962
Flushing, NY
Emitting a greater than zero amount of UV doesn't imply a harmful amount. Additionally, what you have the arrow pointing towards is likely an intentional artifact of graphing. The broken line right above the zero axis exists simply to continue the spectral plot over the entire x-axis range. It's a bad convention which misleads people into thinking there's a small y value, instead of zero. A better way to do it is to simply have the x-axis range only exist for non-zero values. Do we have the raw data this plot was made from? No. Therefore you can't imply anything about what happens at the extremes.
Yes, LED spectral output can and does change over time. However, the shifts are slight, no more than a few nm in either direction.
A shift from white to purple is caused by the phosphor coating degrading and/or delaminating. The allows more of the color of the royal blue LED to get through. And yes, if you've ever looked at royal blue LEDs, the color is indeed purplish, or more accurately violet since purple is a mix of blue and red.
Olumin
The spectral shift of LEDs is mostly due to the aging and degradation of the phosphor coating, usually caused by heat. The output of the chip itself is very stable.
@chillinn what you are saying is technically accurate, however it is trivial. Take this example; Mineral water contains uranium, tiny trace amounts of uranium. While it is technically accurate to say that mineral water contains uranium, it is trivial, as it has no meaningful impact on anything due to the extremely small amounts present. The levels of UV in white LED lighting are simply not relevant, specifically in regards to grow lighting & plant damage.
chillinn
Mobjack Bay
What amount of UV is not harmful?
What?! Oh, ok, it's a graph, but pay no attention to that low amount of UV it shows, it's just an artifact. Right. LED does put out a small amount of UV, but that's not what we see there... just an artifact. ><
Now you're just making things up. Ok, man, you win. Whatever you want. I was completely wrong! So sorry. Are we done? kthxbai
Oh. Ok. Thanks. My mistake. There's no UV in grow lamps and there's no possibility an LED floodlight phosphor could be so damaged over time that the amount of UV output increases, casting a purple light, or killing grass. turbodog and I are just mistaken. Thanks CPF!
PhotonWrangler
In a handbasket
Shorter wavelengths attract small flying insects. Obviously this is why bug lights are yellow. I'm betting on insects here, especially since the articles I'm finding suggest that NUV and blue wavelengths help drive photosynthesis and are beneficial for plant growth. Another article here.
Also I've had some Cree bulbs go dim but I have yet to run across one where the phosphor has burned away or fallen off. I'd like to see a pic of that lamp.
turbodog
central time
Not seeing significant bug action yet this year.
turbodog
central time
Not in an area where there is foot traffic. This is on my house.
There are 11 other floodlights from cree that are fine. This one just decided to die an early/weird death.
Getting a pic of a purple floodlight's illumination area, at night, without using a flash and comparing that to a daytime pic of a dead grass oval/ellipse is more effort than I want to put into this.
But the dead grass exactly matches the primary/brightest light coming from the flood.
Will replace bulb today and see if grass recovers.
desert.snake
Eastern Europe
I have a searchlight in a neighboring yard, it also has an oval blue spot. But this was due to incorrect focusing of the COB, like this
There are a lot of assumptions here and many are quite plausible. I would like to know the brand and model of this spotlight to see what it contains. Or a photo of him.
From the description, I still didn't understand, is this a spotlight for plants or is it a spotlight for people?
There are plant lights on the market that do not have 2 LEDs (blue and red), but three LEDs (blue, red, UV), and more LEDs like
desert.snake
Eastern Europe
Glory to Google!
It's too weak to harm the grass - 13.5 W
Seems like he just overheated and his phosphor deteriorated
10 years warranty, if you still have a receipt and if the store is in the same place with the previous owner, then you can get a new light bulb or contact CREE directly
turbodog
central time
Not worth the gas.
My take is that the new color spectrum is tricking the grass into trying to grow all night... depleting some resource.
Or maybe it's just a very weird coincidence.
