Now it is true, I could have calibrated it to overdrive the LED and give more output than that emitter normally did, or I could have calibrated it to run far under what the LED is capable of. There are several LED options available right now, including a group buy for 4 different color temperatures which is exactly why the emitter in this pass around is unimportant.
The build, the feel, the UI, the programming, the ruggedness... that is the heart of the light, not the emitter which already has several options available. If you don't understand that, you don't understand HDS lights.
Speaking as someone who has no stake in this discussion, having just stumbled across both threads, I think perhaps you shot yourself in the foot on this goal by pushing it so hard. If you hadn't added the stipulations about discussing the LED and output, then as you say, nobody who understands HDS lights would have cared. At most, they would have commented that they'd order theirs with a different LED. But by pushing so strongly to keep that information out of the discussion, you actually called more attention to it. From where I'm sitting, the lumens and LED being used are currently the most interesting thing about the pass-around light, specifically because they're mysterious. Psychology is funny like that.
