Jayrob, got my complete 2D w/voltage moinitor yesterday. I'm dying because my batteries aren't here yet and I don't have anything around right now that will fit. I can't comment on the beam yet, but the overall build quality is very impressive! I am very satisfied with it and can't wait to power it up. You've got me itching for a 1D stubby now!!!! Anyways, thanks again, for such an outstanding service/product, and I'll get back to you when my batteries arrive (hopefully just a day or two). Also, what is the maximum input voltage that will work with the driver? Did I read right that it is 15.5 volts? I was thinking just to try it out I could rig up a sleeve to hold 4x CR123's.:naughty: Thanks again, Tom
The driver comments on KD says you can use 3 X Li-Ion's. But do not do that!
I have found out the hard way that the driver will deliver too much voltage to the emitter with 3 Li-Ions...
2 X Li-Ion's is perfect though.
You can use a 3/4" PVC sleeve for using 2 X 18650's to try it out. Just wrap tape on the ends of the sleeve to fit the Mag barrel.
The only thing you will need to do, is adjust the tail cap spring. The battery is smaller in diameter than the spring. But that is an easy thing to adjust. You can just use some pliers to re-shape the spring.
Looking forward to your comments on the light when you get a chance to try it out!
