gearbest
- Joined
- Aug 27, 2014
- Messages
- 2,070
September 11th New Arrival:
1.HKV A15 LED High Power Diving Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009789576955.html?wid=1433363
Main Features:
• Aviation aluminum alloy shell has excellent scratch resistance and corrosion resistance
• It can be used for 100 meters underwater
• 3 kinds of light can be adjusted underwater: white, blue and red
• Dual-lubricated O-rings provide dual safety for underwater use
• High performance integrated cooling surface on the base ensures low heat
• 4 × 18650 lithium-ion battery ( not included )
2.MT35Plus Super Bright Outdoor USB Charging Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009939052333.html?wid=1433363
Main Features:
• Aluminum alloy, practical and durable
•Key breath lamp design to detect the voltage and remaining power in time
30 percent above, green light is on, 10 to 30 percent, red light is on, 10 percent, red light is flicker.
• PTZ hole design, can be used for fixed lighting
• Underwater 1m waterproof capacity, 1.5m anti-fall rating
• Four modes: moonlight file, medium bright file, high brightness file, very bright file
• Silicone button, widened and non-slip
• 2 × 18650 battery / 4 × 18650 battery ( not included )
3.WUBEN A21 Portable Super Bright LED Flashlight – BLACK
https://www.gearbest.com/led-flashlights/pp_009529056619.html?wid=1433363
Main Features:
●Aluminum body material
Using aluminum body material, it is non-slip, waterproof, and abrasion resistance.
● Side button switch design, easy to use
●Light modes
5 modes / strobe / stepless dimming design, so many brightness options are convenient for us.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable
●IP – X8 waterproof
● Powered by 1 × 21700 battery ( included )
● Light source: CREE XHP70 LED beads
iSDT C4 Smart Battery Charger LCD for AA AAA Li-ion Battery
https://www.gearbest.com/chargers/pp_1628808.html(link is external)
The iSDT C4 Smart Fast Battery Charger is designed for charging 6 slots of 3 kinds of various rechargeable batteries simultaneously.
3A per channel and max 8A output makes charging quickly.
Six charging and discharging modes to meet all your charging needs. With a 2.4 inch IPS LCD screen, you can know the charging situation easily.
Support USB output, you can charge your smartphone at the same time.
Fast charging: support 3A per channel and max 8A output, quick charging
Battery size: AAA, AA, 10440, 10500, 12500, 13500, 13650, 14500, 14650, 16650, 17650, 18650, 20650, 22650, 26650
