Get Nitecore LR12 Flashlight Discount on GearVita
gearvita
Designed for outdoor lighting, the Nitecore LR12 flashlight is an incredible 2-in-1 design lantern flashlight that utilizes a CREE XP-L HD V6 LED to emit a max output of 1000 lumens. Crystal Coating Technology combined with PDOT (Precision Digital Optics Technology) for a peak beam intensity of 6900cd and a peak throw of 166 meters. When the diffuser is extended, the LR12 can be used as a camping lantern for 360° flood illumination. When the bar is retracted, the LR12 doubles as a handheld searching flashlight. And the diffuser can be retracted when the LR12 needs to be stored or packed.
Measuring only 4.18" in length, and weighing only 2.77oz, the size of it is compact and portable. Powered by 1×18650 batteries for a max runtime of 900 hours, it provides long illumination in outdoor. And the operation is as simple as loosening and tightening the tailcap to change 4 brightness levels and 1 special mode.
Moreover, there is a magnetic base enables the LR12 to be firmly attached to any metal surface like car hood or tent pole, and a metal loop enables the LR12 to be hung, suspended or fastened to other objects for hands-free application. With the versatility and User-friendly design, the LR12 is perfect for camping, hiking, searching, and emergency backup lighting and so forth.
Now GearVita provides you the discount below:
10% Off Coupon Code: NTLR12
Coupon Price: $43.14
Coupon Time: July 6 - July 18
Purchase Link: https://gearvita.com/nitecore-lr12-1000lm-flashlight-camping-light.html
Product Features:
Compact 2-in-1 Lantern Flashlight
The NITECORE LR12 gives you the power of a compact everyday flashlight with the utility of a retractable diffusor to instantly convert your light into a pocket-sized lantern. A XP-L HD V6 LED emits up to 1000 lumens output with up to 182 yards of throw which is plenty of light for household tasks, searching & inspecting and all your other EDC uses. Only a twist away is the retractable diffusor that turns your output into soft, 360° ambient lighting you can use for camping and emergency backup. At 4.18" in length and 2.77oz, the LR12 can be carried comfortably, even in your pocket!
Adjustable Output with a Twist
With four total brightness outputs and beacon mode, you'll have the right light you need for any job. The LR12 uses an intuitive twist control to turn the light on and off and adjust output. Simply tighten the tail cap completely to turn the light on and loosen it to turn off. Repeating this action within 2 seconds will cycle the light through ultralow-low-mid-high and beacon outputs. The LR12 uses 1x 18650 or 2x CR123A batteries to operate and can run for up to 900 hours on the lowest brightness.
Hands-Free Options
Equipped with a magnetic tail cap, metal hanging loop and lanyard, the LR12 gives you plenty of ways to secure and position your light. Whether you're sticking the lantern under the hood of your car or suspending it from a tree branch, an IPX8 water proof rating and 1m impact resistance will keep the light safe in tough conditions.
