georges80
I've run some efficiency measurements with my son tabulating the readings (Vin, Iin, Vout, Iout). I then calculated Pout versus Pin and graphed the results.
I performed the tests with 1 x P7, 2 x P7 and 3 x P7 at 2.8A drive current. Obviously the P7's are in series, so a higher total Vf as more P7's are connected together.
So, here's graph, Vin is in volts. The production driver will be somewhat more efficient (maybe 1% or so) due to lower loss in the polarity protection circuitry (FET rather than Schottky diode).
1 x P7 (3.5V x 2.8A) = 9.8W output
2 x P7 (6.82V x 2.8A) = 19W output
3 x P7 (10.2V x 2.8) = 28.5W output
A 3 x P7 light with 4 cell li-ion battery pack would have the driver running around 93% efficient at 2.8A.
I'll have to run similar tests at lower current to see how the driver performs. Though, from a driver power dissipation point of view (keeping it cool), it's nice to see the efficiency increases as the load increases (i.e. it runs more efficiently with 3 P7's versus 2 P7's versus 1 P7).
The driver is more efficient when the input voltage is closer to the output voltage which is what one would expect with a switching converter so no surprises there.
Edit: Ok, ran similar tests with 1.7A output and the efficiency curves follow very closely within a couple of percent. So, it would appear that the main effect on efficiency over a reasonable range of current is Voltage In versus Voltage Out and Voltage Out. As can be seen from the above curves, efficiency is higher at higher output voltages (more P7's) and when the input voltage is closer to the output voltage.
cheers,
george.
cheers,
george.
