NewBie
*Retired*
Another method for doing this that has proven itself with the cavers is to go PWM.
The well known and infamous LVR regulators for bulbs are designed by Willie Hunt, and you can contact him at [email protected]. It has multiple selectable brightness levels, and has been around for many years, well known, established, and reliable. The multiple levels are extremely handy, especially when you don't need peak lumens and would like additional runtime.
http://www.cs.indiana.edu/~willie/lvr.html
His regulators can handle up to 25 Amps and are 99% efficient.
It varies the PWM duty cycle as the battery voltage drops to hold the bulb brightness constant.
Bulbs are much more suitable than LEDs for PWM, as they respond much slower, responding more due to the heating cooling time constant of the filament, and an average state is reached. LEDs respond extremely rapidly, and an average state isn't reached, even pulsing at 1,000,000 times a second.
(don't get me wrong, there is nothing wrong with PWMing LEDs, when the maximum current is limited).
Though, I didn't see where he mentioned inrush current limiting, there are several ways of doing it, you could run linear up to the point where the bulb filament heats up, then switch to PWM, or run the PWM very fast in the beginning, then switch to a lower frequency once the filament was heated up.
Or you could go all the way and add the cap and inductor, ending up with a switching supply, which you can fully soft-start and all, and if you choose the right switcher chip, you can go to 100% on.
