I just got a light from DX, R2 led - 18650. The reflector is all OP, yet there is hardly any flood or spill, and just a tight hotspot. Is it possible to spray it with some clean lacquer or something to get rid of the hotspot?
I'd first look on www.flashlightlens.com to see if there is a compatible lens and add Light Diffusing Film. I myself, prefer a floodier beam than a tight hotspot and find the LDF does a very good job of spreading out the hot spot.
Yes you can. Do a search on sputtering. If you sputter it a bit differently than usual you can get a lot of flood out of it but will also loose a bit of brightness.
