- Joined
- Jan 14, 2010
- Messages
- 205
Like @Mr. LED said the glass is pretty recessed and protected by the bezel. There is always the sapphire lens.Isn't a bezel up carry have more chances to scratch glass ?
The clip works really well for me, for several reasons.. The clip on the light is very comfortable to hold, and does not interfere with the rotary dial. The shape and postion of the clip also make it really easy to slide onto a seam, using only one hand..Looks great 👍
agreeit won't interfere with the tail.
By swapping to the thicker O ring, it is possible to keep the reflector spacing at stock distance, so the beam does not change. This uses the clip between the reflector and the bezel, as the OP recommends.
Another issue to be aware of, the clip rests lightly on a part of the body that turns when removing and installing a battery. It is helpful to lift the clip slightly while installing and removig the body from the head. There is also some fine tuning that may be desireable to increase clip retention pressure.
I still respect the oft repeated warnings that clips are more prone to having a light fall out of pocket, than carrying unclipped, inside a pocket. Its good to have choices. I sometimes wear pants or jackets with zippered pockets.. if Im seriously concerned about my activity level creating a risk of losing a pocket clipped light, I move it to a more secure pocket.
I also like this clip install option:
but Im not set up to drill and tap, and the changes to the body are not reversible.
congrats.. I dont own those tools, and seriously considered reaching out for your help.. but.. so far.. Im enjoying exploring ring clip options. There are three different ring clip options Im learning about, more details in this albumI did mine with a drill press and hand tap.
