I use the Storacell packs for most of my cells. The easiest way to tell the difference is to put the full cells in with the positive terminal towards the open end of the slot. Then, when you replace a run down cell with one of the fully charged one, just put the empty cell in with the positive end towards the closed end. Makes it easy to tell at a glance which is which. I don't use the Storacells for my 18650 lights, since another member reported problems with the fit being very tight, to the point that the wrapper was torn. I use the standard plastic 'travel soap' type cased for those. There, I use the same method. The charged cells have the top facing away from the hinge end, and the drained cells just the opposite. Again, easy to tell at a glance.
