it indeed is not easy.
you either pull out the cell, and wire the whole thing externally, then assume that you also now have wire resistance.
that way you can put the Battery IN the curcuit, and the meter too.
or you can try and make a wafer connection and attempt to stuff it in between.
metal, plastic insulator, metal. then you connect to the 2 metal strips.
the quick one shot method i use, is connect the meter to the top connection, then use the 2nd lead to PUSH the battery away from the connection. if you have enough spring that works and is quick. but it would be impossible to leave it there.
a cheap ammeter can only read sooo much , if the thing uses high rate PWM for charging it might be averaged it might be way off, so one other trick is to switch to AC current, and see if anything shows up there TOO. if current shows up on the AC setting, then chances are the DC meter cant even read it all or correctally, and you need a scope thing.
at any rate everything is in series to check for the current.
+ charger to +ammeter -ammeter to + battery - battery to -charger
or of course the ammeter can go anywhere
+ charger to + battery - battery to +ammeter -ammeter to -charger
is the same thing
