Holidaycoro has similar DMX modules, and i see several in different web sites with all different prices from $8 to $25 apiece. Labels are sometimes different as is the case. But, are these all the same inside?
Also, i see some are specified as 12v, some 24v, another that said it works with 5v-24v. Some say specify at time of order which you would like. Do they all work with 5v-24v, or are there really different models?
Edit- i also just noticed that some say 4A and some say 2A, so that's looking like they really are different devices. I wish there were more specs or manuals online, i can use several dozen, but it's a lot to spend without knowing the differences between the similar modules.
Are they actually supplying constant current? I'm guessing that you have to insert a limiting resistor on each of the outputs- the output voltage is always the same as the input?
Here are two links, one to the holidaycoro version and 2 others i found, they look a bit different, are they the same?
http://leynew.en.made-in-china.com/...DMX-Model-Controller-LN-DMXMODEL-3CH-LV-.html
http://www.holidaycoro.com/3-Channel-DMX-RGB-Controller-p/26.htm
http://store.creativelightingdisplays.com/3-Channel-DMX-RGB-Controller-3CH-DMX.htm
Thanks
Thanks
