"Introducing "Draco" [Accepting Deposit].
Status
Not open for further replies.
jdriller
New York
Re: Introducing "Draco"
Confirming, #63 switch to Al, complete light with uPic. $150?
jar3ds
USA
dang... now i'm seriously debating getting one of these beasts :)....
TSWrench
Modamag,
I am #94. Unfortunately, due to bad timing, I can't participate in this purchase. Great light though!
loalight
San Frandisco
confirming my interest in Al, SN not important. further options to be spec'd if I get off the back-up list!
JimH
San Jose, CA
1st choice TiN with turbo. 2nd choice/2Nd light Aluminum with turbo. Both high/low only no flupic.
dduane
Alameda, Ca
dduane said:
Tony, I'm back from NYC and see it's time to order. I'm #58, Al, with turbo head. Any side by side shots of standard and turbo? I'll call you about which emitter and uPIC. Thanks, Duane
FINAL ANSWER= Al, turbo, hi/lo AND AAA body(edit).
THANKS
luxlunatic
SoCal
I must surrender my spot #72 from the list :sigh:, too many fingers in too many jars.
tdurand
Wisconsin
Just a post to tidy up my picks...
Slot #4 = TiN / Turbo on the side / Ubin / AA tube TBD / Serial #4
Slot #64 = TiCN / Turbo on the side / Sbin / AA tube TBD / #4 if possible
Slot #86 = Al / No turbo / Sbin /AA tube TBD / #4 if possible
Thanks!
T
tdurand
Wisconsin
Also John,
Could you link post #341 (the pricing) to the #1 post?
Thanks
T
karlthev
Pennsylvania
Slot #9 serial #9 if possible, TiN Draco, U bin Lux III, TiN Turbo, uPIC, extended battery pack. Slots 10 and 11, still thinking... :ohgeez:
Karlthev
Lynxis
Vancouver, BC, Canada
To Confirm...
#131 ....
Aluminum 6061-T6 Draco, & Turbo-Head
uPic PWM, UWO? bin Lux III,
extended battery pack (pending price)
modamag
Bay Area, CA
All, the current production run is the 100x Aluminum units then 100x Titanium (50TiCN / 50TiN), in that order.
I will not be taking any payments until we are closer to completion. A 50% deposit is required after machining and remaining balance will be settle prior to product shipment.
Please check with Post #2 for all updates.
srue: The duty cycles of the uPIC converter will yeild an approximate equivalence of 60-120mA on low / 350-400mA on high / ALL OUT on burst.
I'm trying to negotiate so that there is no premium on the uPIC & Lux III at the current moment. Worst case scenario it will be $5. The uPIC will be on-off-on-off, each time it goes on the state changes. While the CC solution is much more finesse, you partially rotate clockwise until LOW goes ON then rotate CW a little more for HIGH. I offer both option, because I know you guys are gonna try to mod this anyway to milk the last lumen out of that Luxeon.
ZeissOEM2: Cute pony :D
Archangel: Post #2 got all the summary and links you need. Specifically here's the beamshot.
tdurand: Unfortunately I can not at this moment. Next week I will do so.
Lynxis
Modamag...
could you clarify...
I'm on the list for #131 ... does that mean I can have the more affordable
Aluminum version or does the #131 imply "which metal" ???
You can shift me to another number for the Aluminium if need be!
I noticed #72 dropping out // I could live with #72
aosty
Modamag... just to clarify... so it is *not* like the FluPIC where you have to single/double/triple click/twist within 800/1200ms to get to the next mode?
Thanks.
:eek:
Status
