Is this normal?
s.e.acree1990@gmail.
Midlothian, Va USA
I am new to rechargeable batteries, and I recently purchased a Malkoff MD2 HA SHO. It says it can use 18650 batteries, and I ordered some from Orbtronic. The end of the battery is starting to show wear, and with all the warnings on 18650 batteries it has me worried. I have only had the light about 2 weeks. I know this might be a stupid question, but I figured I would ask on here as a long time lurker. Thanks.
alpg88
The cell is a bit to long for this light, spring is pushing hard, this is a protected cell, so pcb makes it a bit longer, use unprotected cells, which are shorter.
desert.snake
Eastern Europe
You can disassemble the tail, remove the switch and smooth out the tip of the spring with sandpaper or a whetstone. I did this all the time with McClicky switshes so they don't scratch my batteries
This is a 16650, they are about 6 years old, these damages were in the first months of their life, until I noticed that the tip of the spring was biting into. Now they live well
The cell length does not matter, Malkoff himself sells the same protected 18650 from Keeppower, they are not shorter than Orbtronic
Monocrom
NYC
Is that rust on the rear of the battery? If so, dispose of it properly and get a new one. I've literally never seen that before, and I own countless 18650 cells.
Midlothian, Va USA
It is not rust. It is the outer coating/layer of whatever material it is has been scraped, or gouged off. I think the other members are right about the clicky switch spring doing it. I have been removing the battery through the tail cap, and it does feel sharp too.
