So I wonder who if anyone new in the NiMH LSD market which might be using Eneloop tech and spec's on their batteries. Something from someone must be out there using the Eneloop patent technology in this space.
While anything is possible, I feel it is unlikely that there are any other technology ownership/licensing arrangements, other than that which may (or may not) exist between Panasonic and FDK. (I mention "may not," because it is possible that even Panasonic owns no rights to the technology, and that any and all "real" Eneloops are only made by FDK. Under such circumstances, Panasonic would be forced to purchase cells from FDK "forever," if they wanted the "real thing." FKD, however, could easily be bound by a non-disclosure agreement which prevents them from telling the world that Panasonic doesn't own the technology.)
So based on the above, I would say you only have two choices: Panasonic ("Made in Japan") and FDK. I would say that comparing HKJ's testing results using his battery comparator, indicate quite clearly that the following two brands of cells are in fact the "same" cell:
http://lygte-info.dk/review/batteries2012/CommonAAcomparator.php
Here is a comparison chart for Panasonic - Eneloop AA BK-3MCC 1900mAh (White) vs. FDK- Fujitsu AA HR-3UTA 1900mAh (White):
Here is a chart for Panasonic - Eneloop AA BK-3HCC 2450mAh (Black) vs. FDK - Fujitsu AA HR-3UTHA 2400mAh (Silver):
I suspect that the greater variation between the "black" (XX or Pro) and "silver" high capacity cells, probably stems from the fact that the increased capacity pushes the technology near it limits, and "pushing the envelop" in such a manner results in greater variation between both cells within the same "batch" and between "batches" of cells. (You will also notice that FDK has elected to rate theirs at "only" 2400mAh.)
In the case of the while or regular cells, the graphs are uncannily close, and demonstrate to my satisfaction that they are indeed the same cell.
