markr6
- Joined
- Jul 16, 2012
- Messages
- 9,258
Looks like someone contacted the very same foreign company that made the lantern for G.E.
Yeah same colors and font, just no meatball
What are the numbers at the bottom of the graph?The 4D cell Traditional Lantern model does the same as well. They all step down numerous times, not just once. I haven't tested if it's voltage related or time related yet. I plan to later by connecting them to a power supply, but am still testing runtimes with batteries of various lanterns.
The Costco 4D/8D (GE) Enbrighten lanterns do not appear to have the same behavior as the 6D cell model Raggie has. This can be seen in the graphs I posted in post #54.
Looks like run time in seconds.What are the numbers at the bottom of the graph?
Subterrestrial is correct. It's the runtime in seconds.Looks like run time in seconds.
You have a lux meter?26.5 like 20 percent
Sounds like parasitic drain, which can be an issue with electronic switches. I don't have one myself and I'm not sure if anyone has measured it. I realize it's not necessarily ideal to store the batteries outside of the lantern, but that's one possible solution. How flat is the top? With some of my wider, flatter lanterns I can set them upside and unscrew the top until the batteries lose contact. That way I don't need to actually remove them.I realize that this is an old thread but hope someone can answer me.
I have a couple of these that I bought at Costco. I keep batteries in them for emergency use. For some reason they are draining the batteries while turned off. Anyone else having that problem or do I simply have a defective lamp.
Thanks
I know that this post is really old, but I too have questions about these lanterns. I bought a couple of them from Costco, put them in the closet and forgot about them. I wanted to convert everything to lithium ion, so I started looking for nominal voltage on my various lights. Unfortunately, I am not highly educated in the area of led technology, and have a small grasp on electricity. I read in this post that some 8 cell have markings and can run off of only 4 cells, but mine simply has green stickers in each battery slot, showing orientation. How can I determine the voltage requirements for these, so that I don't burn them up, attempting to use li ion, instead of alkaline?
Lynx_Arc,I know that this post is really old, but I too have questions about these lanterns. I bought a couple of them from Costco, put them in the closet and forgot about them. I wanted to convert everything to lithium ion, so I started looking for nominal voltage on my various lights. Unfortunately, I am not highly educated in the area of led technology, and have a small grasp on electricity. I read in this post that some 8 cell have markings and can run off of only 4 cells, but mine simply has green stickers in each battery slot, showing orientation. How can I determine the voltage requirements for these, so that I don't burn them up, attempting to use li ion, instead of alkaline?
