F89
- Joined
- Mar 15, 2014
- Messages
- 1,428
I've never had a protection circuit fail. While I use both types, I always use protected with two cell lights for obvious reasons.
There is not a speck of dust on this thing…it's brand new and no other cell types (cr123) or 18650 with a cr123 spacer, have any issue at all. I even tried loosening the tail cap to relieve some pressure on the batteries in case that was the problem and it still has an issue. I guess I'll only really know after trying a different type of 18500 and if that does not work, maybe exchanging the body for a different one.You mentioned using a little bit of steel wool when cleaning the threads/contact surfaces before. I wouldn't do that in future.
A rag, paper towel, tissue, whatever is fine with some sort of cleaning fluid or contact cleaner is all you need generally. I use isopropyl alcohol but even some diluted dish soap would be fine.
That said, I wouldn't use acetone either.
So I actually tried the 2 18500 with a cr123 spacer in an md4 body and still had the same issue.Still sounds like a contact issue to me.
The body is simply a conductive tube, so as long as everything is making contact and in working order (head and tail cap/switch) everything should work fine.
I get that it isn't though from what you're saying.
Check all the surfaces, threads, and connections are as they should be. Make sure everything is screening together firmly and that the head and tail cap are also clean and free of any debris that could obstruct them from mating cleanly.
That's unfortunate to hear.So I actually tried the 2 18500 with a cr123 spacer in an md4 body and still had the same issue.
Well I'd rather have it be the batteries than the lights themselves, but I am just hoping the other model of keeppower 18500 work ok because protected 18500 seem limited.That's unfortunate to hear.
The p1850c3 (which is what I have) isWhat's the length of the batteries including button top protrusion? Usually you can even look it up in their specs (you could compare the two even).
I'm not sure exactly, but the 18500s definitely sit higher than the cr123. Gene is sending me the body extender kit to see if that fixes the issue with these cells, but the 18500 with md3 is such a widely used combo, so I don't see how I could be the only one with an issue if it's the cell size causing the problem.What's a CR123? About 34mm?
So about 102mm for three?
Yes. It made no difference. I think it may actually be that there's too much pressure being put on the protection circuit, causing operational inconsistencies. Therefore a body spacer kit may fix the issue.Yeah, it sounds tricky.
Safe to say that 2x18500 (protected) is longer than 3xCR123.
Did you try the sheet of paper?
Then this really is a mysterySome of mine sit at that height and no problems here
Yep. To me it still sounds like a contact problem but how I'm not quite sure.Then this really is a mystery
