I have been using a BC-900 as my primary charger for about 10 years now with no problems at all. When it came out there was talk about how it would melt batteries etc. but I have experienced none of that. Purely anecdotal, but I believe that there are many more good La Crosses out there than bad. It is easy to use and gives a lot of info about the condition of the battery. Especially handy is the refresh mode that will discharge/recharge up to 20 times until there is no improvement in the measured mAh. I recently found an old Eneloop from 2006 that measured 340 mAh on charging but after almost 3 days at 500 mA charge/250mA discharge now reads as 1948 mAh. I believe that it probably went through 5 or 6 refresh cycles. All my Eneloops from 2006-2008 are still going good at around 1950-2000 mAh with refreshing occasionally as necessary.
I usually charge at 500 mA so that the battery is not stressed. It takes a little longer but I always have a fully charged battery ready to go so that there is no need to rush the charging at a higher rate. The BC-900 is a great charger in my experience and I expect that the BC-700 is similar.
The Opus looks interesting and the single advantage that I see is that it has is the ability to do Li-ion. I have a separate Nitecore Digicharger for my LI-ions. I note that the Opus will refresh only 3 times in the refresh cycle so that it would be necessary to run the cycle again perhaps to be sure that you have refreshed the battery completely.
Your experience may vary, but for 10 years of service keeping my envelops going for about 30 bucks is pretty good and I have a high regard for La Crosse and what I consider to be a good , durable product that they produced.
