here's some readily avail spectras...
Merc w/phosphor
pure xenon
incan
Ol school floro
Warm white GE Stick
Nichia 219b
Cree warm white XML2
Thanks, Fritz.!!!!!!!!
That post does tell me a great deal, about where my CD-R tube is by comparison. Still we need a side by side shot of the same light, by same person, with the film vs. the cdR. The diffraction grating film is better defined, but perhaps, not light years ahead of the CD-R:
These are my images of my 4000K metal halide 400watt probe start, and a 4watt China direct filament circa 2015 purchase.
I took a paper towel cardboard center, duct taped a round yogurt container onto one end, wallpaper bladed a mm slit in bottom (or used old solder iron), tightened up slit with duct tape on either side, duct tape a quarter blank CD on opposite end after pealing off its metal film by exacto knife around edges and duct tape pulling off metal film. Probably, I should melt groove or carve CD before scissoring of a CD R quarter. DVD R failed for me, had to use the recommended cdR on my second try. Duct taped outside for sturdiness and make inside darker. I did use black spray paint on yogurt, not tube, not sure if needed... I built another from a Pringle can, but don't think it long enough to get the definition.
Now, your diffraction grating film bands are a more defined, probably less work getting the picture. The 219 and xml are beautiful. Some of your geometry is very interesting, and I would like to know more. The defined bands in the florescent are spectacular.
So far, have not looked up lines per mm on the cdR spec.
