Leaking alkaline batteries
adrianmariano
It seems like I have recurring problems with alkaline batteries leaking. I had a streamlight LED that took 3 AAAA and I noticed at one point that it wouldn't turn off completely. I inspected the batteries and found that they had leaked. Since that was a rarely used light I figured it was just a bad idea to let the batteries sit in the lights. I took the batteries out of all but the two lights I use regularly.
Recently with another streamlight (7 LED 4 AA model)--one of the two regular users--I used the light and it seemed decently bright, and then I noticed that it wasn't turning all the way off. And sure enough, the batteries had leaked.
Why are these batteries leaking? I recall hearing that alkalines might be subject to leaking if they get overdrained, but these batteries were stilling giving decent light output.
ltiu
Texas
Brand matters. My Energizers, Rayovacs and Duracells have never leaked on me.
supes
GA,USA
I thought my AAA's would be leaking in my lights now, but somehow I have had 2 separate occassions where I thought to be trusted new Duracell Coppertops AA to destroy my Inova and LED lantern.
Both times, I got reimbursed from Duracell though. Excellent CS!! But now I don't know if I would trust Duracell without doubt anymore. I guess it happens..
VidPro
Lost In Space
DONT MIX
beyond them being discharged, there is the reverse charge issue, which gets many consumers, because they just stuff some battery that fits into a device.
EVEN though the instructions on most of these devices, in the first part of the manuel with all the rest of the garbage nobody reads :) it says, dont mix brands, styles, types, age, or drain ammount . well something like that.
when you use batteries in SERIES, you should use the same brand, the same type, the same package, the same ammount of use, if you mix up batteries in a drawer (we all do even me) then toss them in something, one could be WAY different capacity.
so ONE cell dies and the others keep going, and the one that died gets a reverse charge, and that can make it more Likly to leak.
so that is one factor, and is more likly to occur in Multicell lights (specially 4X or more).
AGE
a second factor is AGE, even if the cell is unused, there is toxic corrosive materials being contained to give you power. the Can that holds this stuff eventually breaks down over time. the more the manufactures shrink the can, to get more capacity, the sooner it can break down. then of course there is probably plastic linings and stuff, but all are effected by age. some manufatures push the edge of this containment envelope to far.
and over time , even without using the battery an old cell might be way low in capacity, which puts it back in factor 1 , one cell dies early.
RECHARGABLES
Most rechargable cells are better sealed, i have never had a rechargable damage a light unless i messed up something , meaning my fault.
TEMPERATURE
Temperatures, people USE this stuff, when they do it can sit in a 140*F car, it can get left in a -20*F garage, and temperatures can cause expansion and contraction of anything, loosening things up , or expanding them to failure.
RUST
water getting into your light, can increase the rate of oxidation,,, etc etc.
most all of this stuff is indicated on some packaging or spec sheet somewhere, but even if you do everything exactally right, stuff still fails, it just fails lots less.
The best thing you can do, is be a teeny bit more aware of all the things that can occur, and tell the "Family" not to mix up cells (takes 5 minutes), use rechargables, and ask the manufacture to repair or replace anything screwed over by thier product, so they Know what is important.
CHECK MORE
open up the light and check the cells say once every 6mo or so, it takes time to do the major damage, and the cells show inconsistancies before they ruin everything. look for changes in color on the wraper, Rust forming on the metal, or what looks like a liquid oil changing the coloration of the wraper.
DAMAGE
denting a battery , even from a hard drop on the floor, even a rechargable, even if you dont see the damage, an internal short can occur, which can discharge the battery or reduce the effectiveness of the seal.
HWman
California
Everyone has had bad experiences with leaking alkalines. Currently, they are not as bad as they were in the past.
Early on, there was no "expiration date". The first printed "expiration dates" were for only a short time into the future (I don't recall, but something like two years). Then, came the built-in battery capacity testers (push the dot and watch the line grow...). Where is that feature today?
If you didn't check your flashlight every six months, you might find massive leaks (not just a drop or two) and salt deposits. I had three or four Maglites ruined in my car's emergency kit. Most of those were Eveready alkalines.
A couple of years ago, I had five of twelve Eveready AAA alkalines leak in the package. From my experience, I would never leave an Eveready alkaline battery in a "good" device for an extended period of time. I would pop them in and run them down, but only if I knew I would be removing them after a short period of time.
That said, I had an "out of date" Duracell AA sitting on the table when I noticed it was leaking. I tracked down the other one in the pair and it was leaking, too. I have described that incident elsewhere (it was in a recalcitrant Inova X1).
Now, I will start relying on LSD NiMh (Rayovac Hybrid) and a couple of boxes (buying one every year or two, depending upon finances) of Kirkland AAs (to be used for a major emergency).
I just hope we find that LSD NiMh batteries also stands for Low Self Destruct, too. (Do I get to copyright that?)
SilverFox
Bellingham WA
Interesting...
I just had 2 Duracell copper tops with a date of March 2011 leak on me, and a third was bulged and looked like it was ready to leak. Let's see, 3 out of 4 going bad, I must have had a matched set.
Tom
adrianmariano
In both incidents, the batteries were of the same brand. In the case of the light with 3 AAAA batteries I know they were from the same package as well, because I don't have a drawer full of AAAA size batteries. Those were radio shack brand (all I could find in the right size).
The more recent incident involved four duracells. It's possible that batteries from different packages got mixed. I saved the offending batteries and can check the expiration dates. I'll also check and see if they exhibit widely varying voltages. Is it possible for four cells in series to discharge nonuniformly so that one ends up depleted in advance of the others?
The flashlight has a pretty large deposit of crud from the incident. The head end with the circuitry and LEDs was spared, but some of it may have gone down into the tail end where the switch is. Any cleaning advice? If I can't fix it and I complain to duracell they will pay for a replacement?
I have thought now and then about maybe starting to use rechargeables but have been discouraged by the self discharge problem. I don't use my lights every day. I don't want my light to not work because I let the batteries sit for 2 weeks, and storing all the batteries in the freezer seems like a bother (how long to reach room temp?). My battery consumption is fairly modest so I haven't been driven by financial incentives to switch to the rechargeables. I did a brief search on LSD. Do the LSDs live up to the hype?
How important is it to use a brand of LSD (Eneloop) vs, say the greenbatteries.com store brand? Has anybody done comparisons of this sort?
VidPro
Lost In Space
the alkaline is alkali , so its a base, and an acid can "nutralise" it, but vinagar the acid that could nutralise it, will blacken raw metal quickly, so I dont try and nutralise alkaline battery spills.
instead i just rince it out with copious quantities of water, (soap is alkaline) use a bottle brush, dry completly (to dry i sometimes flush the water out with 99% alcohol which drys faster) and then clean all the contacts with sandpaper or a file , then recoat with something like a silicoln spray or special de-oxit stuff.
the manufactures say things like "will repair or replace after you mail it to us" and you pay to have it shipped to them. if you send it in to manufacture, you basically want to leave it as-is, so they accept that it is thier fault. somebody said, they asked them to remove the batteries, but long ago you would just send the whole mess into them.
LSD enloops are good so far, Silverfox tested them, as did others, just search enloop in titles. nobody can know about total time with the LSDs yet because they have not been out for long. i have been using them since they came out in singapore.
series cells are Supposed to have the same current flow on each one in the series set, so discharge should occur evenly. but there is a situation that occurs, i dont know how to explain, where the top battery, the one connected to the + side of the light, can discharge faster (if i remember right) , it was sugested that it might have to do with the HEAT at the head end of the light? i donno. but science says the current flow is the same, and the science is right , if you include all the science , like mabey the heat?
adrianmariano
Streamlight has a good guarantee, so I could send it back to them. But if it's really Duracell's fault it seems kind of lame to make Streamlight bear the burden.
The problem with doing a decent cleaning job is that there is no obvious way to get at the contacts which are at the tail end. One of them is a spring which is going to be pretty hard to clean well when it's stuck at the end of a 5 inch tube.
With unregulated LED lights like the Streamlight will I lose a lot of brightness if I switch to the enerloops? Any charger recommendations?
louie
Seattle
IIRC, the Streamlight 4AA LEDs are disassembled by unscrewing the rubber switch cap, which has the threaded switch retaining ring inside it. Then the battery contact+switch assembly falls out from the inside.
I've seen plenty of leaking alkalines and see no pattern myself. Last week, I just noticed a puddle of liquid next to my desk phone, and sure enough, one of the Rayovac Industrial C cells inside had recently decided to leak. The cells were probably 5-7 years old, though. I must've caught it fairly soon as the damage was minimal.
VidPro
Lost In Space
theres gotta be a way
make a new tool, stick sandpaper to a stick? scrape the metal with a screwdriver. get a Wire brush bottle brush at the auto store, get a extention line on your dremmel tool, and use the wire brush.
the streamlight propolymer thing with the 4AAs is not unregulated, if that is the one your referring to, there is even a recent thread on it, showing the great curcuit in it. i have seen the streamlight PP 4AA thing running on ni-mhy, the user said it worked fine like that. from what i know it should work great on ni-mhy, but i dont own one.
flashfan
USA
I've had problems with C-cell Energizer alkaline batteries. At different times, they've leaked in a Trek 19, an Underwater Kinetics 6C, and a Streamlight Twin-Task light.
The batteries in the Twin-task leaked so badly that I couldn't even get the batteries out of the light. In addition, the rubber switch and the reflector were badly deteriorated, so I just tossed the light.
I've also known people who've had problems with Duracell batteries leaking in Gaglites (various sizes).
adrianmariano
I tested the leaking batteries (after cleaning off the contacts) and found them all to be 1.2 V to within 0.02 V. They all had the same expiration date as well. So it doesn't look like a mismatched set. And from what I understand, 1.2 V isn't particularly low.
I tried to unscrew the switch and couldn't turn it. Trying to clean the springs with sandpaper on a stick or a screwdriver might be good for a rough cleaning job, but if I'm trying to get the contacts clean and shiny that's not going to cut it.
I'll clean what I can reach, and if it doesn't work after that then I guess I'll send it back.
What happens to NiMH batteries if you leave the light on indefinitely?
lumenal
Johnson Point, WA
You must be talking about the Streamlight Stylus. I have 5 or 6 of them, all loaded with 3 AAAAs. ( But not for long, although I did check them a couple months ago, and all was well).
They are rare, but there are NiMH quad As. (AAAA). I saw a link posted here recently, but I don't think they were LSD. Maybe try a search?
And, at the very least, a NiMH cell may be ruined if one leaves a light on indefinitely. :crazy:
parnass
Illinois, USA
Here is another technique to reduce damage from leaking cells.
Write your name and address on a piece of paper, roll it into the shape of a tube, then insert it into the flashlight between the batteries and the barrel inner surface. This won't work if the batteries are too tight a fit.
The information on the paper will identify your flashlight if you lose it.
adrianmariano
Yes, it was a streamlight stylus with the three AAAA's that I had problems with a couple years ago. I did send that one back to streamlight and got a replacement which actually was better made. And since then I don't keep the AAAA batteries in it. I also responded to the leakage problem by putting lithium batteries in the emergency light in the car and in my wife's rarely used Arc keychain light. And I took the batteries out of all the other lights I have that I don't use regularly.
The light that just suffered the spill problem was a Streamlight Propolymer LED 4AA which I use as my general household light.
Sarratt
Ottawa, Ont. Canada
Is there any way to visually check to see when I cell is going to leak ?
This post , thanks adrianmariano , comes at a time when I'm worried about cells in my lights
For regular cells ...does turning them on once a week help?
Beyond taking them out of my lights how else can I avoid a leeky cell
M
Power Me Up
Brisbane, Australia
Not that I'm aware of. Often the wrapper will become discoloured from leaking material before it does any actual damage - but you can't count on that - and that's not a warning that it's going to leak, since it has already started!
As a test? No - leaking cells can still run a flashlight.
Replace them with low self discharge rechargeables such as Eneloops of course! :grin2:
adrianmariano
The flashlight that provoked me to start this thread was still working. I knew there was a leakage problem because it wouldn't turn off properly---it remained dimly lit even when I switched it off. But when it was on it was acting normally.
I've had leaks in batteries powering a digital scale which is used daily, and a clock which is on continuously. So regular operation is clearly no cure.
With the new low self discharge rechargeables it seems like there's no excuse to continue using alkalines, so I'm going to switch over. They are only in AA and AAA right now, but the majority of my stuff runs on one of those two sizes.
