There are now a lot of CPF'ers with their own lathes and with the exceptions of those in the business, and one or two lucky individuals, it is safe to say that most of us own manual lathes.
And, I would venture to guess, that the most difficult operation to learn is threading. Sure, there are lots of books and online resources to guide you--to show what the difference is between an ID and an OD, say, or why the lathe cuts right-hand threads when the tool moves toward the headstock. But when it comes time to choose which cutting tool you will use, getting helpful information is a hit or miss proposition. If you are lucky enough to know a machinist, you've just saved yourself a lot of trial and error.
But even if you were to watch a machinist do threading, while you may get the basics down real quick, did you also learn that there are a variety of inserts, or threading bars, that you can pick from? Sure, sure, you know that the toolbit is a 60-degree included angle, you know about side clearance, rake, etc., and you've learned how to set the compound slide to 29 to 29.5 degrees for the starting passes, and how the final cuts should be done with the cross slide being moved into the piece.
But, but -- do you know that there is a threading bit that actually gives one visual signals that you've reached the proper depth of cut?
Tonight I was working on the DG Light, in Ti, after having completed most of the AL prototype. I needed to cut the threads in the bottom of the head and the top of the battery tube, so that the two pieces would mate properly.
Here's the battery tube, which was threaded to accept the head, and in this photo, I'm testing the fit with the previously cut AL head of the DG Light:
And here's a close-up of the threads in the battery tube, showing the O-ring landing and then the threads:
Next, I had to complete the threading on the head. First, though I thought I'd show how I prepare the piece for threading. Here's the piece ready to be threaded:
From left to right: The body of the light, with the machining marks clearly showing. Then there is a .5mm flat that will be the visible portion of the battery tube that shows when the twisty is in the off position. By having that flat there, one does not see the ugly black O-ring!
Next is the O-ring groove, although it is not to final depth yet--I do that when completing the light. Just to the right of that is the thread relief bevel that I cut for the end of the threads. The reason for doing that is to avoid the ugly burrs that would occur if the threads simply ran into the O-ring groove. Then there is the wide, flat area that is to be threaded, and, finally, the last item to the right is the bevel leading into the threads. That is a 45-degree bevel and seems to work great for getting pieces to thread together seamlessly.
Well, if you are still with me, you are about to see the magic toolbit that shows you when you have reached the proper depth of cut for your thread pitch. This photo shows the insert, which is traveling from right to left, as it is nearing the end of the preliminary passes/cuts that were made by advancing only the compound slide, set at 29.5 degrees, into the work piece.
NOTE CAREFULLY: See the swarf coming off the insert? Notice that it twists to the left:
Now why is that, you may ask? Simple enough--the tool is cutting on its left edge only and it is moving from right to left also. So the chip curls off to the left as well.
The final cuts on the work piece, to reach the final depth of cut, is done by advancing the cross slide, which means that the insert will now be entering the work piece perpendicular to the work piece. As a result, the insert will meet the uncut right flank of the V-groove of the thread and cut there primarily, or certainly will cut more metal on that side than on the left side. Now, the next photo is the first cut with the advancement into the piece coming from the cross slide only.
NOTE CAREFULLY: The chip is now curling to the right! Bingo! We are very close to the proper depth of cut.
If you now take another cut, a very shallow one, you will be able to see the chip looking more like flakes, than as a curling chip. Time to either stop cutting, or if you have the mate, test fit the pieces together. Like this:
And finally, the end of the road:
So what are these magic inserts? Well, they are full-form threading inserts--and that basically means that they not only cut the groove to the proper depth, but they also cut the crest of the thread as well. The end result is a very smooth thread, one that does not need to be sanded with anything, not even ScotchBrite!
For those that already knew, all this, and more, I apologize for the lengthy post, but I'm sure that there are some newbies that will find something of use in their forays into the world of cutting threads.
