LED bulb question
cmac57103
I would like to find LED bulbs with the following characteristics:
Type: 921 compatible
Temp: 5000K daylight, 4400 may be OK, 6500 is too blue
Lumens: 500-2000
Application: room lights in my RV. Any suggestions will be appeciated!
evilc66
I'm curious why you are specifying 500-2000 lumens as the desired output for an LED lamp, when the incandescent versions are typically around 260 lumens (from what I've found so far)? I think you are going to be hard pushed to find a neutral white LED lamp with more than 170 lumens, and that's with a lamp that is taller than standard so they may not fit in all situations.
