Update on the IC. I got them from dat2zip last week (BIG heartfelt thanks to Wayne for getting these for us) and notified the people on my list above on how to get theirs in the mail.
The circuit I made (pictured above) was used for the test, replacing the dummy sot23-5 that you see in the picture. It charged my bare 18500 cells at 714mA, as advertised. You can monitor the charge current on the PROG pin according to the data sheet and I monitored the current this way, watching it taper off as the cell approached full charge. Nice little IC. You can also drive a LED using the /CHARGE pin if you want a simple charge status indicator. All in all, I really like this thing. If you have a microcontroller with an A/D, you can really get carried away building a full featured charger.
Another reminder for those wanting to build their circuit. Make sure you use a VCC as close to the minimum as possible. The data sheet states 4.25V min, 6.5V max. This is a linear circuit which means voltage in excess of the minimum required will be dissipated as heat in the IC. I use a 5V 1A wall wart to supply this breadboard and didn't notice significant heating. It is thermally protected to 120 deg. C at the die. Read and understand the data sheet and it should give you many years of trouble free operation.
CM
