Light Review: Olight S1 plus Special Edition S1 Ti
subwoofer
Hove, UK
Olight's S1 is the smallest light they have ever produced with a side switch. Along with the standard aluminium edition, Olight have created quite a storm of interest by also releasing several different Special Editions with different emitters and materials such as Copper, Titanium as well as Gold-plated versions.
Taking a more detailed look at the S1 (standard Al edition):
Olight's standard plastic box packaging displays the S1 nicely.
Inside the box is the S1, a CR123 cell, spare O-ring (which is actually used to hold the S1 in place) and a wrist lanyard. A really thoughtful feature is that the lanyard comes with a threading wire fitted to it to make it easy to fit to the S1.
The S1 itself has a stylish two tone appearance with the bezel and switch rings in blue.
Keeping the size down, the tailcap is a very streamlined design. The spring clips into a slot and is used to hold the magnet in place. This makes it easy for the user to remove and replace the magnet.
The threads are square cut and as the body is short, there are not many actual threads.
Peering inside there is another spring terminal and an anti-rattle closed-cell foam pad.
Looking dead-on, the S1 has a TIR optic and the actual LED cannot be seen.
In a less common format, the cell is inserted negative towards the head and this is clearly marked on the side of the S1.
Just to give an idea of how compact this light is, here it is next to the already small Olight S10R (another RCR123 light).
Also for scale here it is in my hand (I take XL gloves)
Before moving on to the Special Edition another quick look at those lovely blue PVD trims.
Taking a more detailed look at the S1 Special/Ti edition:
In keeping with its Special Edition status, the Ti S1 gets a different box.
Presentation is excellent.
Inside the box is the S1, a CR123 cell, diffuser, instructions and a wrist lanyard. A really thoughtful feature is that the lanyard comes with a threading wire fitted to it to make it easy to fit to the S1.
A glorious looking light.
The clip is removable and reversible.
Construction of the tailcap is the same as the standard version with the terminal spring clipped into a groove and used to secure the magnet.
Square threads are used.
Looking inside the internals are the same as the standard version.
A Rose Gold plated bezel surrounds the TIR optic.
Without the diffuser fitted.
With the diffuser fitted.
For the special editions they have the identifier 'Ti' and a serial number engraved on the tail-cap.
Small, Shiny and Ti, a winning combination.
The beam
Starting indoors with the Standard S1. The wide hotspot transitions into a wide spill giving a great all round beam, and one that works really well for EDC tasks.
The main difference in the Special Ti Edition is...
...For the full set of beam-shots, please go to the Exclusive Content at Tactical Reviews, but remember to return to this forum to discuss the review.
Modes and User Interface:
The S1 has five output modes, High, Medium, Low, Moonlight and Strobe and a single click-switch on the side.
Basic ON/OFF operation is carried out with a single click of the side switch. The S1 will turn on to the last used standard mode (this does not include Moonlight or Strobe).
To change the brightness, while ON, press and hold the switch to cycle through Medium -] High -] Low -] Medium etc. Release the switch once you have the required output.
There are a few special functions:
Moonlight mode - from OFF, press and hold the switch for 1s until the Moon mode is activated.
Direct access to High - from OFF, double-click the switch.
Strobe - From ON, triple-click the switch.
Timer - From ON, double-click the side switch. The S1 will blink one or two times. Once means the 3 minute timer is activated, twice means the 9 minute timer is activated. To swap between 3 and 9 minutes timers, double-click the switch.
Timer mode means that the S1 will turn itself off after the specified time, and this can be started from any mode (including Strobe and Moonlight).
Batteries and output:
The S1 runs on either CR123 or RCR123.
For Detailed output measurements, please go to the Exclusive Content at Tactical Reviews, but remember to return to this forum to discuss the review.
Peak Beam intensity of the S1 Al measured 3500 lx @1m giving a beam range of 118 m.
Peak Beam intensity of the S1 Ti measured 3000 lx @1m giving a beam range of 110 m.
There is parasitic drain but it is very low. For both the S1 Al and Ti, the drain was 1.1uA (145 years to drain a CR123 cell)
The trace here shows each of the S1 versions running on CR123 and on RCR123. The most distinctive difference is...
...For the runtime graph, please go to the Exclusive Content at Tactical Reviews, but remember to return to this forum to discuss the review.
Troubleshooting
This section is included to mention any minor niggles I come across during testing, in case the information helps anyone else.
The Olight S1 in use
In reality there is little difference between these two versions in terms of practicality, except perhaps the neutral emitter in the Ti version. Of course the Ti version feels much more special and looks the part, as do any of the S1 special editions.
Regardless of special edition or not, the S1 is an excellent EDC light and won me round straight away. Easy and reliable access to Moon mode, direct access to High and memory of the last standard mode used, all tick the EDC boxes; all this and never forget its super compact size which makes it very easy to carry.
The built in timer is great for giving the light a 'sleep' mode so if you are camping or otherwise in need of a period of 'settling-in' before going to sleep, but not wanting to then have to turn a light off; it will turn itself off for you. Think of your own uses for this; I really like it even if I don't use the timer all that much.
Being able to pop out the tailcap spring and remove the magnet is a really clever design. Magnets are useful, but very often I get annoyed with them picking up this and that. Now I can choose to have the magnet or not.
Deciding between CR123 and RCR123 will be personal preference. For heavy users the guilt-free-lumens of RCR123 may be a better match, but check that runtime graph; a sudden cut-off might be a problem for some users. If it is a problem, stick to CR123, as for general light EDC use it will last a long time.
Thanks to the very low parasitic drain, you can be confident that leaving it loaded up with a CR123, the S1 will be ready to go when you need it, and you won't find it with a run-down cell. If you are super-paranoid, you can lock out the Standard version by unscrewing the tail-cap half a turn. You cannot lockout the Ti Special Edition like this as the threads are not coated.
Although a TIR lens was chosen for better control of the beam shape, it has the added benefit of being pretty much unbreakable. That beam is a general purpose beam which is well suited to closer range typical EDC uses.
Even though I'm use to it, I still have to think twice when putting a new cell in, the 'negative terminal towards the head' layout seems a strange choice when convention has the positive terminal towards the head. It does include all the relevant protection in case you get it wrong, but this seems an unnecessary unconventional touch.
The switch is quite low profile and without the clip often needs a bit of 'hunting' to find. The clip, which seems relatively large, can act as a guide for finding the button, and also helps stabilise the grip. The S1 is small enough that is can feel insecure to hold, especially when performing multi-clicks of the switch; the clip gives a little something extra to get hold of.
Small, good looking and full of useful modes that are easy to get at. It is no wonder the S1 is proving very popular.
Review Summary
______________________________________________________________________________________________
Things I likeWhat doesn't work so well for me
Very compact.Sudden cut-off when using RCR123.
Great UI and selection of modes.Unconventional cell direction.
Takes CR123 or RCR123.Special Edition version cannot be locked out.
Very low parasitic drain.
User removable tail-cap magnet.
'Proper' Moon-Mode (with direct access).
Timer mode.
UnderPar
Philippines
Amazing review SW! As always. I have the aluminum and Ti polished version of this light and I loved every details of it. Thank you for sharing this review...
Lou Minescence
New England US
I'm not sure what you are asking. Please elaborate if something needs further explanation?
I remembered the different metal versions being termed " Limited Edition " lights. Just wondering if there was something new coming out.
Also the referred to gold plated version, is that the rose gold coated copper light ?
Thank you
subwoofer
Hove, UK
Thank you
Ah, in my dealings with the S1, Limited and Special have been interchangeable. Yes the gold-plated one is the rose gold-plated Cu version.
I'm hoping Olight will release a few more Special editions, but I've not got any exciting news about that.
NoNotAgain
Blue Ridge Mountains, VA
There are a few other versions available, but are limited to two different copper lights and two that are exclusive to Going Gear.
They offer two brass lights.
This light is limited to rather short RCR123 batteries as neither my Fenix or Efest cells fit.
subwoofer
Hove, UK
One of the reasons I prefer AW RCR123s is that they are the shortest I've ever used. Good point to raise, thanks for mentioning it. I'll have a look and see if I have any 'long' RCR123s to try.
akhyar
Malaysia
With my slightly long Keeppower protected 16340 inside, it's kinda PITA to screw the tailcap of the S1.
I'm pretty sure it might have squeezes the springs inside my S1 very tight.
No problem with normal size AW 16340, Soshine 16340 and other CR123 that I have.
derfyled
Great review and most of all great pictures, no... fantastic pictures. :thumbsup:
Why I won't buy it: AL version only available in CW. TI or other exotics metals are NW but no locked out mode possible and I see it easy to activate in pocket by mistake.:mecry:
swan
Banned
sydney aus
Thanks subwoofer for the review of these great little lights.
I have a copper, aluminium and a ti - l find the size [tiny] power and beam shape makes it stand out from the rest of competitors.
With the choice of cell- my AW rcr123,s protected cells trip at about 40mins and also can trip around 3.5v resting if i call on turbo. So i prefer to run an [AW or Efest] unprotected IMR cell which will stay in regulation on high for 60 mins and will not trip out. At 60 minute mark [59 min aw 61min efest] you will see the output start to drop and then a slow flashing telling you its flat. Of cause i do not run it this low, but its their if i need it.
subwoofer
Hove, UK
How about the side switch waterproof performance?
I have no way to test waterproofing properly (particularly just one aspect of it) as it would need something similar to a watch seal tester. The manufacturer has rated it at IPX8.
NoNotAgain
If you're looking at a quick way to determine the waterproof ability of the light, take a clear bowl of water and heat in a microwave oven for 2 minutes. Lower the light into the water and observe for bubbles.
The temperature change will increase internal pressure and not allow for water intrusion.
Been used in aerospace to determine sealing of aircraft assemblies for many years.
derfyled
That's a nice way to check, never heard of it before. Thanks for sharing ! :thumbsup:
subwoofer
Hove, UK
That is a great simple idea but not quantitative.
For me, that would need a few extra parameters for temperature and if the light has a cell fitted or not. The amount of air inside the light will affect the pressure this test develops so a 1x18650, loaded with 2xCR123 will be different and more so if no cells are in place. The starting temperature of the light also matters, perhaps only in relation to the water temperature.
If you can standardise a few aspects, I wonder what the equivalent depth actually is. Perhaps this test is very simply 'not waterproof' or 'might be waterproof' rather than 'definitely waterproof to at least 1/5/10/20m'.
Amurr
Really thinking about picking up a special edition. Such a great value also.
