I am thinking about the Imalent MS06 (25000 L/513 M, 3x 21700, 572gm w/cells) as being in between the TM06sVn 4x 50.2, 9800 L/415 M, 446gm with cells; and the X45Vn, 25000 L/775 M, 700gm with cells. Closer to the size of the former, and closer to the power of the latter, and halfway in between the with-cells weight of both.
And, also, this:
https://acebeam.ru/katalog/kupit-moshhnyj-poiskovyj-fonar/acebeam-x65gt
Google Translated:
The Acebeam X65-GT is a heavy-duty professional searchlight that uses fourteen original Luminus SBT-90.2 LEDs as a light source with a maximum combined luminous flux of a record 50,000 lumens. At the same time, the location of each LED in a separate deep smooth reflector made it possible to provide a throw of a uniform bright light beam at a distance of up to 2000 meters, which makes it possible to use the flashlight not only at industrial, airports or quarries.
As a power source, the flashlight uses a rechargeable cell based on eight rechargeable lithium-ion batteries of size 18650, which can be charged directly inside the body of the lighting device. A network storage device is included with the model.
Specifications:
LED: 14 LEDs Luminus SBT-90.2
Maximum brightness 50,000 lumens;
Operating modes: 6 levels of brightness + special signal mode Strobe
Rechargeable battery: 8 Li - Ion 18650 batteries;
Maximum range: 2000 meters;
Impact resistance: 1.2 meters;
Waterproof: IPX-8 (submersion under water to a depth of two meters for up to 30 minutes without loss of performance).
Features:
Digital voltage regulation system to maintain a constant light brightness without flickering as the batteries run out
Intelligent thermal control (automatic dimming of LEDs when reaching critically high temperatures inside the case)
Memory of the last used brightness level before switching off
Battery level indication
Anti-reflective coated mineral glass lens
Impact bezel that protects the lens from breaking if the flashlight falls
Suitable for use in strong subzero temperatures
Efficient heat dissipation from LEDs through radiator cooling fins
Aviation aluminum alloy body
Additional hard anodizing for corrosion protection
Control instructions
The flashlight has a convenient operating mode control scheme based on one button located near the head of the body:
on / off - one full press of the button;
selection of the required brightness level - by pressing and holding the button (cyclic change of modes);
activation of Turbo mode - two quick clicks of the button when the light is on (the next two clicks of the button activate the Turbo-Max mode);
turning on the stroboscope - three quick presses of the button.
The battery status indicator is integrated into the flashlight control button:
green indicator - 40% or more charge;
red - less than 40% charge.
If the battery charge level drops to 10 percent or less, the brightness of the LEDs will be dimmed automatically.
