LiIon charger recommendations
fixit7
I am looking for recommendations for LiIon battery chargers.
I mostly use 18650s, but would like to be able to charge most other types including LiPO.
I also need one that is able to charge the batteries one at a time.
I have read reviews but often get conflicting reports.
Thanks.
ChrisGarrett
Miami, Florida
Thanks.
What are you reading, that's conflicting, on this site?
http://www.lygte-info.dk/info/indexBatteriesAndChargers UK.html
HKJ does a lot of testing, so look through his results and see.
When you mean "one at a time", do you mean individually, as in four separate channels in a charger, or do you mean, you want only a single bay charger, not a two bay, or four bay?
Opus BT-3100/BT-3400 are 4 bay, multi-chemistry chargers that charge just about everything that we use. They're about $40, so fairly inexpensive and they run off of a 12vdc wall wart, so you can use them in the car, boat, or with 12vdc solar panels in a pinch.
Chris
