Looking at the pdf manual for this charger, I see:
NEW-i4_UM_EN.pdf said:
When charging this type of battery, please manually set the charging voltage to 4.35V, otherwise the charger will charge at 4.2V by default, and cannot provide adequate charging voltage
Can someone (ahem, HKJ) please comment on the possible or expected results of charging a cell that should properly be terminated at 4.2V (such as LiMn IMR) that is instead charged to 4.35V?
I have a charger from the same manufacturer, and it only will charge at 750mA max. According to the new i4 manual (the i4 is not "new," but might be distinguishable from an i4 charger not designated "new" on the packaging), cells terminating at 4.35V need more voltage applied, but the charger should default to 4.2V termination mode, and would need manually set in 4.35V termination mode.
I know that my charger will sometimes flip it self out of the manually set LiFePO4 charging mode, back to the default Li-ion mode, so I must watch carefully when charging LiFePO4 cells. But I have never seen it flip from default auto mode to the manual LiFePO4 mode. I have also seen the charger recognize older, well used and perhaps abused higher-resistive NiMH instead as Li-ion. The snafus I sometimes to infrequently see in my D4 don't seem too troubling to me, as I am usually nearby to adjust it if it chokes on identifying the cell, and the way it chokes doesn't lead me to believe something nasty will happen, even with LiFePO4 cells charging to 4.2V (though this is not in any way good, LiFePO4 is presumably resilient enough to not go critical, and all my LiFePO4 cells are 10440, small cells, small energy content).
But if it were possible that the reverse could happen, that a Nitecore charger could flip inadvertantly from auto 4.2V mode to manual 4.35V mode with a IMR18650 LiMn, or if accidentally set manually to 4.35V termination mode, I would be very concerned that something bad could happen, due to the high energy content of the large cell, especially if it was a higher capacity 3000+mAh variety.
Anyone else own and know the i4? How is it set manually to 4.35V termination mode?
My D4 requires holding down one of its chicklet-style buttons to manually advance the mode, but I am aware of chargers from other manufacturers that utilize slide on/off switches, sometimes these switches are internal and difficult to access. I see it as a possibility in the slide-switch-style chargers that could inadvertantly ship in the incorrect default configuration, and the end user would never be aware until examining the switch, or until it was too late.
