Lumintop GT Mini - The Mini Version of BLF GT
gearvita
Based on the model BLF GT and the original design team, the Lumintop GT Mini flashlight is a mini version thrower runs on a single 18650 cell. Compare with GT, the tiny size allows it much convenient for carrying and one-handed control. By adopting the Cree XPL High Intensity LED, it emits a maximum output that exceeds 1200 lumens and a beam distance over 750 meters. Easy operated ramping UI, multiple modes designed, press the side switch to gradually ramp up the output. IP68 rated dust and waterproof protection, GT mini is essential for a task as searching and rescuing etc.. It's got knurling on the handle and circular, machined cutouts toward the head for a comfy grip on the base or on the head.
Main Parameters:
LED: Cree XP-L high intensity LED
Peak Beam Intensity: 135,000cd
Light Color: Cool white, natural white
Max Output: 1200 lumens
Peak Beam Distance: 750 meters
Power Source: One button-top 18650 or 18350 (short tube required) li-ion cells
Waterproof: IP68, underwater 2m
Product Features:
● Cree XP-L HI LED, neutral white or cold white optional, maximum brightness can exceed 1200 lumens.
● The maximum light intensity is 135,000 candelas, and the maximum range can exceed 750 meters.
● Runs on one button-top 18650 lithium-ion battery or 18350 battery with the included short tube.
● Use 17W, 4.5A FET drive, standby current is 27μA when shutting down.
● Constructed of a durable aluminium alloy with a stainless steel bezel ring.
● Premium type HAIII hard-coat anodizing finish.
● Inner diameter 43 mm aluminum alloy glossy reflector.
● Easy access to different brightness levels with memory function.
● Light-transmitting silicone button for comfortable touch.
● Default button illuminated back-light while off, easily locate the flashlight in the dark.
● Anti-reversed design, prevents reversed battery installation.
● Lock out function prevents accidental activation.
● IP68 waterproof, underwater 2 meters.
Get it from GearVita, while it'll make a great companion for searching and guiding the way, the GT Mini also tailstands if you need to set up camp or read in the dark: https://gearvita.com/lumintop-gt-mini-led-flashlight-cree-xpl-1200-lumens.html
Related products:
lumintop odl20c
manker u22
