Lumintop HL18 - Multifunctional Headlamp, Handheld Flashlight, L-shape Light
gearvita
The Lumintop HL18 is a high-performance multifunctional headlamp that also can serve as a handheld flashlight, L-shape light. By utilizing Cree XP-L HD LED, it delivered a max 950 lumens output. 5 output levels plus Strobe, SOS and Beacon, satisfy various lighting demands in different environments. Floodlight design provides a large and balance beam for wide rang illuminations. Micro USB charging allows you to charge the lamp more convenience. Soft and comfortable silicon holder, and reflecting anti-slip headband gives you a more comfortable wearing experience. One switch operation, strong magnetic tail cap, stainless steel clip, IPX-6 waterproof standard, all these designs make HL18 is essential in your mountaineering, climbing, searching, rescuing, hiking, camping etc.
Main Parameters:
Emitter Type: Cree XP-L HD
LED Lifespan: 50000h
Max Output: 950 lumens
Max Beam Distance: 70m
Peak Beam Intensity: 1225cd
Battery Configurations: 1 × 18650 battery or 2 × CR123A batteries
Waterproof: IPX-6 standard
Impact Resistance: 1.5m
Output and Runtime:
Turbo: 950 lumens ( 2h 45min )
High: 400 lumens ( 3h )
Med: 200 lumens ( 6h 45min )
Low: 40 lumens ( 34h 15min )
Moonlight: 1 lumen ( 18.5 days )
Strobe/SOS/Beacon: 950 lumens ( / )
Product Features:
● Utilizes Cree XP-L HD LED with a lifespan of 50000 hours.
● Max 950 lumens output and 18.5 days max runtime under Moonlight.
● Made of aerospace-grade aluminum with premium Type III hard-anodized anti-abrasive finish, 1.5m impact resistance.
● One switch controls 5 output levels plus Strobe, SOS and Beacon.
● Micro USB rechargeable, with charging and low voltage indicator, easy to know charging situation.
● Silicon headlamp holder makes a comfortable wearing.
● Detachable reflective and anti-slip sweat-block headband.
● Detachable stainless steel clips allows more wearing manners.
● Magnetic flat tail cap with tail standing ability.
● Multifunction serve as a headlamp, angle light or flashlight.
● Floodlight design creates a smooth and comfortable flood beam.
● Compatible with 18650 or two cold-resistant CR123A batteries.
● Waterproof, suitable for rainy weathers.
For detailed operations and details, please refer to GearVita. The beam is wide and powerful for a greater field of view. Though it's meant to be used with the adjustable strap, the light can be clipped or magnetically connected to something for working under the hood or illuminating a tent: https://gearvita.com/lumintop-hl18-led-flashlight-950-lumens.html
You may also be interested in:
buy xiaomi huami amazfit bip smartwatch
buy xiaomi redmi note 6 pro
