Silverfox,
Thank you for the information! That really helps out since I am expecting mine to arrive tomorrow. So the 800s is exactly the same as the 801D except for the slower charge rate, right? Thanks again!
Yes, like normal discharge batteries, they benefit from a few cycles before use, and heir capacity will come up slightly over the first few charges.I got myself some LSDs, finally.
Should I do a conditioning cycle on these?
-Mike
I contacted them about a month ago for something different. Also no answer.I tried emailing Maha USA a month or two ago asking where to get a replacement. No answer.
Recently its power supply died; it's a "MKD-48180800 18V DC 800mA"
Charger says "DC 12-18V input" positive center.
What do I look for to replace this?
That's the first time i heard of that happening. I have that same charger, and it works flawlessly time in and time out. Must of been a defective unit. Maybe the employee who assembled it had a bad day.hello everyone:
I'm noob here at CPF, I had been lurking around for sometime and learn a lot from so many CPF guru here. I just purchase a 808M a month ago from a photoshop here in Manila(they distribute the Maha charger in the Philippines). and these charger perform very well until the the 11th of August. I use the charger to condition and charge my AA,AAA C and D cell, of both nicad and inmh chemistry.
When I plug in the charger on the 11th, I saw little smoke came out of bay no.8 of the charger near the DIN 1 connector, then the LCD display start blinking all the time with a done display on bay no. 8(without any battery in the charger) , I try to unplug and plug the charger again after a few minute, the same thing happens. (blinking LCD display and done on bay no. 8 ):sick2:
I bring the charger to the photo shop, and they replace the defective one with a brand new unit . I hope these unit will last!!:sigh:
mikevelarde
Paging SilverFox or William Chueh
He knows that. He mentioned both as they both likely have a good answer.those are two different people lol
I recently purchased about a dozen of the powerex 11,000 mah D cell and proceed to condition 8 of them in the 808. after 5 days. the 808 seems to get stuck at the discharge cycle with 1 bar blinking on all slots without going into the final charging cycle. The 808 seems to be overwhelm by the capacity of the D cell :thinking: and their algorithm get mixed-up because of the time needed to discharge those D-cells????
