Quickbeam
I purchased the C808m a few weeks ago, and it seems to do a great job.
Doug P.
Doug P.
Is this also true for eneloop NiMH batteries? That the trickle charge will be less than the self-discharge rate and thus be insufficient to keep the AA and larger size cells fully charged when left on the charger?SilverFox said:...
Looking at these numbers, it seems that even if you leave the cells on the charger, the AA and C/D cells would still self discharge faster than the charger could trickle charge them. In light of this, I still believe it is better to develop a habit of charging your cells before use. You will usually have enough left in the cell to be able to use them even if they have been sitting for a month or two or maybe even three. If you don't use them within a couple of months, you will be better served with primary cells.
Tom
SilverFox said:Hello Ben,
I just pulled 8 cells off of the charger. Most of them were at 1.44 volts. The lowest was 1.43 volts, and the highest was 1.46 volts.
Your cells at 1.39 and 1.40 volts do not seem to be fully charged.
Tom
How do they fail?eav2k said:My third Maha MH C808M charger just died. The first lasted about two months, the second about a month, and the third about 3 months. They all died the same way, after trying to condition AAA cells. I got this charger from Thomas Distributing; who have the best customer service I have every encountered. I would be willing to try a forth C808M, but if I do get one I will not try to condition AAA cells with it. Has anyone else encountered this problem? Note that prior to these failures the chargers worked great.
Those two chargers complement each other very well. I have both of them and together they are the best of both worlds.SilverFox said:...The AccuPower20 has the advantage of smaller size, is able to operate on 12 volts, it has the ability to charge 9 volt batteries, and costs less.
The C808M has the advantage of being able to charge more cells at a time, it offers 2 charging rates of which both are higher than the AccuPower20, charging high capacity cells is faster because of the higher charge rate, and it has the ability to discharge cells in the conditioning cycle.
Tough choice... perhaps you should get both.
Tom
Sub_Umbra said:Those two chargers complement each other very well. I have both of them and together they are the best of both worlds.
The AP2020 is gentle...but may require ~36 hours to charge 10,000 mAH NiMH D cells. It may seem worse in real world situations. Since the AP2020 has only four bays it will take around three whole days to charge a 6 D NiMH set for my CD boombox. The C808M makes short work of them. It's kinda breathtaking...
All of my AAAs get charged in the AP2020. I still use some 1,000 mAH AA NiCads and I prefer to only charge them in the AccuPower since the C808M will revert to it's default 2A charge rate if it's power is interupted for even a half second.
The C808M is so fast that I may charge over 120 NiCad and NiMH cells while a hurricane approaches by using both chargers. (I use, rotate and maintain all of those cells on an ongoing basis.)
For me, I wouldn't want to be without either of them. I still hope to run the AP2020 on solar eventually.
