TorchBoy
I have one from this year that stops at 1.46V or 1.47V with my Eneloops, before the top-up charge which takes them to 1.50V or sometimes 1.51V. Which version is yours, jusko?
......Which version is yours, jusko?
Wow, thats a lot of time to try and recover a set of cells. I guestimated that process would take approx 25 days for 2000 mAh cells.However, there can be some educational opportunities from playing with crap cells.
If you want to play, try this...
Hello Handlobraesing,
OK, so your crap cells show 0 mAh under a 100 mA discharge on the C9000. What do you get after running the Break-In cycle?
Tom
OK, we are making progress here...
So far your crap cells have 0 mAh capacity after a normal charge and a 500 mA discharge, and 0 mAh capacity after a 0.1C charge and 0.2C discharge.
Yet you claim that under a 250 mA constant load they work fine.
It's time to put them in a direct drive light, turn it on and let it run for around 4 hours. Hopefully you have a single cell light. If you need to run a pair of cells, you will have to watch it to make sure you don't ruin your crap cells further by reverse charging.
At the end of this, you will need to jump start the cells to get them to have enough voltage to start the C9000. Once you get the voltage of the cell up to where the C9000 recognizes it, you can run another charge/discharge and see if you get past 0 mAh.
Tom
It depends on what you want to measure.I just got a C9000 last week and am in the middle of running a couple break in cycles on some new Eneloop AAA & AA and old Rayocac NiMH. When that is done which mode should I use get the most accurate display of their capacities?
Where can I do this and what kind of cell will they accept?I might add that it is better to recycle than to toss in the trash...
Yes, you can. I have found the capacities reported by the break-in cycle to be quite repeatable and consistent. If one cell comes up low the first time round it will come up low the next time you test it too.I am trying to keep it as simple as possible and hopefully match the cells in the process. From what you stated I can use the reading at the end of Break In to get an idea.
Actually, because of the pulsed discharge, it give slightly optimistic results compared to constant current discharging...
When you move on from crap cells to healthy cells, what are you finding?
Tom
