Malkoff for Mechanic/Vehicle Maintenance
md17
usa ct
After getting my first Malkoff a few weeks ago, it's become apparent I need more.
What is a suggested set up for mechanical work on vehicles that will require long on times and moderate output?
ilikeguns40
Western PA
2xAA body running two 3.7v 14500s will also provide long runtimes. The higher the voltage the less mah draw on these new heads
md17
usa ct
ilikeguns40
Western PA
Wonder how these are for protected 14500. After my recent battery length issue with the 18500 I want to make sure I get it right the first time.
Those are fairly long and may cause issues with spring and switch
I would get Vapcell F12. That's what I run. Don't worry about LVP. Once voltage is low enough the light won't work
When output levels are all the same. Just change or recharge batteries. Vapcell F12 are INR and are much safer than IMR or ICR
md17
usa ct
When i work on cars or anything else, I use a headlamp, can't really do much work with one hand, while the other is holding a light.
I have a streamlight protac headlamp I use occasionally, but I do find a handheld useful for a lot of the work I do. And malkoff doesn't make head lamps yet, unfortunately.
kerneldrop
South
He's got a headlamp strap for MDC lights
bykfixer
Dust in the Wind
I like the MDC 2AA for this one.
- Shirt pocket when not in use.
- SST for a nice narrow hot spot for peering into the abyss of modern engine bay spaces.
- Some eneloop pro's would be a good fit.
kerneldrop
South
On average SST-20 needs 2.71 volts for the LED to light up. I wonder what the runtime is on two eneloops before the voltage drops below 2.71.
ilikeguns40
Western PA
Not quite sure but,
I did a runtime test with a CR123 and a SST20 3.4-6v MDC head on high and got around 3 hours, yes I said that right.. 3 hours. Didn't have time to test it further so I had to stop
Obviously wasn't the max output as with a 3.7v 16340 but I'd say an estimate of 100-150 lumens with CR123
