Manker MK39 Ranger - A Very Adaptable Flashlight with Handle
gearvita
The Manker MK39 Ranger flashlight is one impressive chunk of aircraft-grade aluminium with premium Type III hard-anodized anti-abrasive finish. Despite its awe inspiring stature is sits very comfortably in the hand and thanks to the positioning of the handle the thumb naturally engages with the operating controls seamlessly. For long periods of use a shoulder strap is provided for easy carry.
The MK39 has a lumen output of 6000 lumens with a choice of flood or focused beam making it a very adaptable lighting tool. Search and rescue teams take note, this torch is capable of an incredible 1100 metre throw. At the touch of the button the beam will ramp up from one lumen all the way to 6000 in unnoticeable increments, allowing the user to halt the process and choose the right amount of light for the job in hand. Plus it has a strobe which can be a very handy tool in an emergency.
Runtimes vary depending on the output being used but the Manker MK39 features a automatic cut out to preserve battery life and prevent overheating during heavy use. Whilst the 6000 lumen output is chosen the torch will drop to a lower level of power after three minutes, which will ensure a longer period of usage on one battery charge.
Main Parameters:
Emitter: Emitters:
- CW: 1* Cree XHP35 HI+8* Cree XPG3
- NW: 1* Cree XHP35 HI+8* Nichia 219C
Maximum output: 6000 lumens
Maximum beam intensity: 305000CD
Maximum beam distance :1100 meters
Working voltage: 11.2V - 16.8V (over discharge protection)
Driver: Most efficiency constant current circuit
Water proof: IPX-8 (2 meter under water)
Impact resistance: 1 meters
Brightness Levels and Runtime:
Throw mode (ramping adjustment): 1-2000lm / 48hrs - 3min + 2hrs
Flood mode (ramping adjustment): 1 - 4000lm / 48hrs - 3min +1.5hrs
Throw and Flood mode (ramping adjustment): 2 - 6000lm / 24hrs - 3min+1hrs
Strobe mode: 6000lm
Product Features:
● Made of durable aircraft grade aluminum material, the surface is treated with premium Type III hard-anodized anti-abrasive finish, lens are toughened ultra-clear glass lens with anti-reflective coating.
● Power by 4x 18650 batteries, maximum 6000 lumens output.
● Maximum light duration of 48 hours.
● Peak beam intensity 30,5000cd, max beam 1100 meters, impact resistance 1 meters.
● Four different light modes and strobe mode.
● High-quality processing water and shock resistant.
● Driver is the most efficiency constant current circuit.
Get it with the price of $173.99 at GearVita.com by using the $25 discount and free shipping coupon code "MK39RANG" when you checkout: https://gearvita.com/manker-mk39-ranger-led-flashlight-6000-lumens.html
Related products:
https://gearvita.com/manker-u22-led-flashlight-1500-lumens.html
https://gearvita.com/acebeam-x80-gt-rechargeable-flashlight-32500-lumens.html
