Mateminco MT35vn - Heavyweight 70.2 Thrower
Newlumen
United States
I don't know why this light require protected. It doesn't effect the performance. Today I am also getting my Sanyo/Panasonic 18650GA. Will let u guys know how it does.
Capolini
Banned
Valley Forge, Pa.
I thought the same thing. I considered that light in the sale and then changed my mind.
Protected or Unprotected GA'S? Liionwholesale has both at Black Friday Prices. Basically selling ALL their batteries at 1000pc. wholesale prices.:D
EDIT: V54 told me that the carrier can take up to 69.65mm. The GA Protected are listed as 69.70mm on Liionwholesale website. MJ1 listed at 69.6mm
Skylumen
Unprotected high drains will hurt the 70.2 in the MT35vn. Run at your own risk.
Sproing
Thanks Newlumen, capolini and Vinh for the responses.
I'll add some protected batteries to go with the Black Friday winning :)
klrman
Is the batter carrier exactly the same dimensions as the Astrolux MF02?
warmurf
Queensland Australia
Hi mate,
I've tried to PM you but it doesn't appear to have worked. Could you please PM me the total cost for this shipped to Australia (Brisbane)?
Thank you! Regards, Ricky
Newlumen
United States
Hi mate,
International shipping is $15, according from the past forum sale..
LichtAn!
Hessen, Germany
Can anyone confirm the battery carrier is a 4 cell 2S/2P carrier? Nvm just found a review on the identical Astrolux MF02. It is 2S/2P. So I'm assuming if you use cells that are somewhere in between VTCs and protected high capacity cells in terms of voltage sag, you could get around 9000 lumens out of this? :eek:
Sun Boy
What current light is similar in spec to this?
$ 175.00
Close Up Video
Night Beam Shot Video
  • Size: 125mm x 84mm x 54mm (length x head x body diameter)
  • Weight: ~1.5lbs with batteries! Excellent heft of heat sinking
  • DriverVNX2 UI
  • Excellent build quality equal to Acebeam, Olight and other major manufactures
  • All 18 LEDs mounted on copper
  • XHP70.2 6500K Only
  • Protected Cells Only
Lumen: 6700
Intensity: 235Kcd
Throw: 970m
+$5 for V54 Engraving
[/QUOTE]
