The LED and or the driver is likely fried. Look like I will need the head back for repair.
Ok, I finally resolved the issue with the battery carriers after seeing the photo that Alex posted. I was assuming the circuit was between both center positive contacts on top and bottom. Now I know the circuit is between the center contact and outside of end of carrier.
So I have 4.15V in each carrier, and have inserted them in light with middle dual spring disc. However no light comes on.
I tried reversing the battery carriers even though they have the same polarity orientation with + center and - outside end plate, still no light comes on.
I have tried fast click, series of fast clicks, and press and hold (all from off), never have had a light display.
I have inserted and removed carriers several times thinking that might reset the chip, but nothing has worked. It is like the light is locked off, or there is some internal short in driver board.
If you have no other suggestions, please let me know If I need to send it back to you to get fixed.
