MBI HF-R Mods?
mbp1
Hi all, I hope this is posted in the correct place, and that "solicitations" of this nature are allowed. I have an MBI HF-R Flashlight I am interested in having modified. Ideally, I would request 3 things:
1) Swap Emitter for a Nichia 219 (currently has XML)
2) Install custom driver. I have the 3 mode version and I just feel the 600 lumen high is too much. It's impressive but I'd prefer more runtime. I know the 219 will produce lower lumens anyway. I'm not sure what's really possible here but I'd love to discuss it.
3) New tritium tubes.
Can anyone recommend me a modder who might be interested in this project?
mcbrat
Iowa
I think I remember other people swapping emitters, but I'm not sure there's room for a driver. The HF series was direct drive, with modes being determined by resistors in the rotary tailswitch.
mbp1
Thank you for the information, this is good to know, not sure if I made clear that I'm definitely a novice with this stuff. Would there be any other way to "throttle down" the output on high to squeeze out more runtime/less heat?
CRX_
Scotland
Where are you located?
The HF-R has resistors in the rotary tail switch, they can be changed to different values altering the output.
There is no "driver" as such, just a contact PCB.
The emitter is fairly easy to swap.
I have extensively modified mine :)
I swapped some resistors around so:
Momentary mode – 760lm
92A – 887Ω to 1Ω – 240lm – 20mins
201 – 200Ω to 2Ω – 150lm – 40mins
150 – 15 Ω to same – 30lm – 220mins
5R1 – 5.1Ω to 200Ω – 10lm
0 – 0Ω to 887Ω – 1lm
mbp1
That is some truly mind-blowing work right there. I am located in the US, in Maryland. I have the 3 mode HF-R with momentary, not sure what options are possible with that. In a perfect world maybe 1-30-150 with max momentary. If you would be inclined to modify another I'd love to talk with you about that!
CRX_
Scotland
Hopefully someone closer to you can help you out with this or you get into moddin' lights :)
mbp1
CRX has kindly offered to mod my light, but given that I am in the US and he is in the UK, I am still searching for others here in the states.
archimedes
CONUS, top left
MBI HF (and related models) are very tiny, and appear to be at least of "moderate-plus" challenge to mod.
You may wish to check with Vinh to see if it would be something he might be willing to attempt ?
That was a kind offer @CRX_ . You seem to be new to CPF ... :welcome:
Just saw your linked photos, that looks to be some very impressive work you've done. I hope you will continue to participate here, and would be very interested in any "build threads" you may want to add ....
easilyled
Middlesex, UK
CRX was recommended to me by a friend on CPF from the UK and I requested him to mod 2 of my brass peaks (Logan & Rainier) into multi-level lights with current emitters and versatile UIs. He did an amazing job on them. :thumbsup:
