So in other words you have your proprietary retainer ring for the McClicky, correct? And that the switch is user-servicable just like with the McClickied Z41?
Sounds like you're using the DX boot with a cuttable center peg inside. Has the boot been further modified for your tailcap setup (eg. trimmed flange)?
BTW I'm referring to the Oveready hard-press and medium-press boots here
http://www.oveready.com/a-upgrades/...tion-clicky-kit-for-z41-p/c/z/g-/prod_23.html
Any pics on the inside of the FM tailcap host, esp. with the switch mecha unscrewed?i've tried OR hard/med press boots and they don't sit correctly in this C tail cap by FM
That would help explain how the DX boot can be properly sit inside while the OR hard/med-press ones can't
Also is the standard (DX) boot being modified for this tailcap setup (other than having the center peg cut out)?
So you're saying, that the DX boot in this tailcap setup is NOT modified, with the center peg/nipple/nub fully retained?I believe it's because of the nub/nipple not being present in the OR tail cap boots
That's interesting... would really like to know how the switch mecha is being installed inside.
BTW @FM what's the height difference between the Z41 tailcap host and your own round version?
