MCE in parallel
jbwiden
I see many people who run the LED's in parallel what concerns me is thermal runaway. I thought LED's have negative temperature coefficients and thus as it heats lowers Vf and draws more current (positive feedback)... Is it not a problem as the LED's are on the same die and they all see the same temperature or some other reason?
What I want to do is run 3 MCE's off of one Hipflex driver from a 13-15 volt source (Automotive 12v when running). What I plan to do is to have each MCE wired in parallel (LED's on each die in parallel) and run the three MCE's in series. So it will be at most ~12 volts at 2.8 amps
Are there any reliability issues with this configuration?
Thanks,
Jbw
yellow
Baden.at
I was one of the persons to doubt heavily that P7 will survive 1 year of service because of parallel wiring
and was wrong
:rolleyes:
obviously it is not this "bad",
or the high power leds have much better (and similar) die, than those crappy 5mm in showerheads.
point is: do it, seems not to cause problems
