Semiman is correct.
Candlepower is just Lux measured at 1m
for example, a light that shows 100,000 lux at 1m has 100,000 CP
Also bear in mind that CP is really only a measurement of the brightest spot in the beam, and tells you nothing about the actual beam, only how it will throw.
Most lights are too bright to be measured at 1m, and many don't actually focus a proper beam until the beam gets out a few metres, so it is possible (and frequently done) to measure at a longer distance, and calculate the lux back to 1m (I can't remember the exact formula though)
I measured my Maxabeam a few years ago, and it measured out at 7.2million CP
that tells you nothing about the beam shape though, other than the hotspot is very bright.
Adding that it's only about 1200-1500 lumens, allows the presumption that it's a very throwy beam (which it is, often described as a white laser)
Heres a pic of the beam, shining a kilometre , you can see the minimal spill on the ground too, on a normal light that would be a very bright white
