Meet Viking Pro Magnet USB
ArmyTek
Berlin, Germany
Hello, guys! We are ready to present you our NEW addition to the tactical lineup!
Meet Viking Pro Magnet USB!
__________________________________________________________________________________________________________________________________________________
Impressive features of Viking Pro Magnet USB flashlight
Viking Pro is a new generation tactical flashlight with soft wide light for hunting in open areas and for specialized tasks. The flashlight can be used right out of the box: the set now includes a high-capacity battery and a fast magnetic charger.
Large central spot and wide side spill make Viking Pro perfect for short- and medium-range use with maximum distance of 284 meters.
Wide beam of light allows to comfortably highlight the objects at close distances of 50-70 meters with the brightness reaching impressive 2050 lumens.
Powerful electronics provides constant brightness even at a temperature of -40 °C and not fully charged battery.
Total protection from water, dirt and dust in accordance with IP68 standard — flashlight continues to work even at 25 meters depth up to 5 hours. Withstands fallings from the 10th floor.
Advantages of tactical flashlights with magnetic charger:
  • Non-flat button allows to easily switch the flashlight with a palm.
  • Active real-time temperature control to prevent overheating above +58 °C and warning indication of low battery level.
  • Magnetic charger in the set
Order Viking Pro Magnet USB today at armytek.com!
http://www.armytek.com/flashlights/models/viking/armytek-viking-pro-magnet-usb-white/?
Thank you for choosing Armytek!
MMCosta
Hi,
I wish I could decide between
ARMYTEK VIKING PRO MAGNET USB
and
ARMYTEK VIKING PRO XHP50
So I came here so you guys could help me with you 50 cents.
Much Obliged
The old version has more modes and for its specs it seem that has a greater spill. 80%
And it seem to hold on max turbo with no falls of lumens. (The new viking usb falls lumens with high temperature)
ARMYTEK VIKING PRO MAGNET USB ARMYTEK VIKING PRO XHP50
Color temperature: WhiteWhite
LED: Cree XHP50.2XHP50
Optics: Textured reflectorSmooth reflector
Light output, lumens: 2200 lm-
Beam distance, meters: 288 m286 m
Brightness stabilization type: Full (constant light)-
Hotspot:Spill: 11°:40°-
Number of modes: 69
Runtime in maximum mode: 1 h 33 min (940 lm after 3 min)1h
Runtime in minimum mode: 32 h200 days
Strobe mode:
Head diameter: 41 mm25.4 mm
Body diameter: 25.4 mm41 mm
Length: 160 mm154 mm
Weight (without battery): 136 g126 g
Material: Aircraft-grade aluminium-
Anti-abrasive finish: Premium type III hard anodizing 400HV-
Waterproof and dustproof standard: IP68-
Safe submersion depth: 25 m50 m
Safe fallings height: 25 m30 m
Operating temperatures: -40..+40 °C-25..+40 °C
Battery compatibility: 1x18650 Li-Ion1x18650 Li-Ion / 2x18350 Li-Ion / 2xR123 Li-Ion / 2xCR123A
Ability to use batteries with PCB:
Ability to use batteries without PCB:
Protection from accidental switch-on:
Color battery state indication:
Indication of low battery level:
LED light output: -2300lm
OTF light output: -1800lm
Hotspot: -10°
Spill: -80°
ArmyTek
Berlin, Germany
is Armytek following this forum?
Hello! Yes, I was just expecting to hear our customers' opinion:)
So, Viking Pro always had a drop in lumens, we didn't mention it in manuals for old version. We only started doing this recently.
Speaking about the brightness. Viking Pro Magnet USB reaches 2200 lm while Viking Pro v3 reaches 1800 lm.
Also, the best update for this flashlight is the ability to charge it with the magnetic charger.
So, I think,the better choice is Viking Pro Magnet USB:)
