So I was able to get the new circuit integrated into a host....
From right to left: A 1.25" compression host with 2 JT circuits each driving one LED with a single pole, double throw switch with center off. This allows the use of one neutral LED (brighter) and one warm LED (low mode) depending on the needs. If you look close, you'll see the second LED towards the front, in front of the rear (lit) LED
Next to that is what was my standard build using a 1" compression fitting and an on/off toggle... this was about as small as I was getting it...
Enter the ZXLD (third from the right) and now I'm in a 1/2" compression fitting and have eliminated the switch all together... Small, clean, awesome!!!!!! (well, awesome to me anyway)
For size reference next to a 6P and an 18650:
I have gotten my taditional JT down to .58-60v before in a straight run, but found it needed about .90 (as you noted) to actually start the circuit. Not yet sure about the ZXLD, but I aim to find out.
Oh, and here's a reading lamp that only a mother can love:
