this_is_nascar
Edit #4 has been added to Post #1 and shows the AW 14500 cell in the D10.
Nice, thanks. Does the D10 on 14500s just completely drop off around 78 minutes then? There's a little uptick there and then nothing.
Also, are you planning to do the EX10 on a RCR123A? That would be great.
I received my EX-10 yesterday and played with it briefly last night (thanks to all at Fenix-Store!)...wonderful craftsmanship and quality to this light. It truly feels great in my hand.
My only hesitation so far has been the mechanics of jumping to "high"...not working for me. My understanding is that when the light is screwed down to "off" position, I should be able to first, click it "on", then three clicks and a hold to "high"? I tried it repeatedly last night...no dice. The two clicks to low works fine.
Anyone else having issues? I'm sure it will turn out to be the "nut behind the wheel"...
In short, the following:
-- much easier activation.
-- much more reliable activation, meaning, once active it stays active without thumb slipage, numbness, slipping off, etc.
-- no kilroy to d*ck-around with, bend, adjust, break, etc. The entire end of the Smart-PD makes contact with the activation ring, whereas the PK must touch the kilroy that sticks out slightly. It makes for an off-center contact-patch.
They are the physical aspects of the Smart-PD that I prefer. The software aspects bring it to even a higher level.
Edit #2 has been added to Post #1, to show runtime on a Duracell battery.
... I'm not real pleased with the regulation of the D10. I was hoping for a flatter curve...
Also, keep in mind the variations in Vf will affect both efficiency and runtime.Looks like the D10 performs a bit better than the EX10 when both using rechargable Lithium Ions cell - 14500 and RCR123 respectively. I bet the runtime would be very impressive on the D10 if the output was backed off just a wee bit. Something arounet 75% - 80% output would produce almost similar output by eye with much better runtime.
Amazingly the D10 on 14500 cell could probably run almost as long as the EX10 on primary if outputs were matched. This is very interesting for a rechargable cell.
Same here, I'm mildly color blind and really have to study and compare some of the curves to match them. When the colors are really close, I sometimes have to rely on my expectations of what the curve should look like, based on past experience, in order to figure them out. Slightly thicker lines and/or larger color samples in the key would be helpful to us.I hope you could improve the legend with a bigger representation of the colour. The thin line at the legend make it almost impossible to read.
